LG 50PK550 clicking - plasma newbie
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    #101
    Re: LG 50PK550 clicking - plasma newbie
    hopefully reece or budm etc may have some ideas where too look next im still learning myself so not sure what to advise as never worked on this psu before
    • jason424
      • Dec 2015
      • 187
      Well I appreciate your help and time spent with me thus far
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        #103
        what i dont understand is before you fitted that ic you had a led on plus a clicking noise so part of the psu was working now your getting nothing.
        • jason424
          • Dec 2015
          • 187
          The IC and that diode is the only things I monkey'd with. And the orig diode was ok in the first place. I'm tempted to remove the IC and the diode and put the old ones back and see if it returns to clicking.
          Unfortunately I can't find a replacement board, or I would contemplate just throwing a new one in.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            #105
            maybe worth swopping back as you suggest just be carefull of the solder pads when you remove the ic maybe once the ics removed clean the board and upload a picture of the pads etc just incase theres a break etc
            • virpek
              • Oct 2015
              • Sweden
              #106
              Hello! Use 20V DC setting on your meter
              • jason424
                • Dec 2015
                • 187
                So I de-soldered the old IC and found that there were pretty much no solder pads present at any of the thru-holes, much like the pic of the break earlier.
                I installed a new IC that I had received later (from China) and installed jumpers (orange and blue dots) and now get 3 clicks over and over when plugged in to power.
                EDIT: unfortunately I forgot to take pics of the board after cleaned/removed old IC
                • jason424
                  • Dec 2015
                  • 187
                  So since I figured I had messed the board beyond repair, I ordered a replacement...from the UK...which arrived today. The set powers on, flashed gray screen a couple times then no pic. Seemed to stay on as the red optical port continued to glow until I hit the power on the front. I can hear a faint hum/buzz on the board.
                  I test the Va and Vs test points with the TV powered on and I get 130.8 and 187.2 then up past what my meter reads. I thought the Va number was high since the white sticker says 60v for Va and 203v for Vs.
                  I have also noticed new behavior on the control board...the green LED does 3 short blinks then 1 long blink.
                  • jason424
                    • Dec 2015
                    • 187
                    So I just went to test the Va and Vs voltages and they were very close to the sticker (60/203) at 59 and 198. I also noticed that the green led on the control board was blinking 1 long 1 short then 1 long 1short again, then a pause. I measured the voltages of the connector from the power board to the main board as shown in the pic attached and got the following:
                    Set plugged in but off:
                    17v: 0.00
                    Gnd: 0.00
                    5.1: .4
                    5.1: .5
                    Gnd: 0.00
                    Gnd: 0.00
                    Stby: 3.4
                    AC det: 0.00
                    Auto Gnd 0.00
                    Tv powered on:
                    17v: 16.8
                    Gnd: 0.00
                    5.1: 5.1
                    5.1: 5.1
                    Gnd: 0.00
                    Gnd: 0.00
                    Stby: 5.1
                    AC det: 2.4
                    Auto gd: 3.3
                    I powered off the set and back on again and got the same led blinking scenario as I did before with the 3 short blinks and 1 long blink.
                    I'm not sure if this replacement power board is bad or if now there is something else wrong?
                    • jason424
                      • Dec 2015
                      • 187
                      Any insight any one can give on further testing to diagnose if its another board or if the replacement is no good?
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        #111
                        im not sure what the blink code means maybe reece has a idea what you can check now as a replacement powersuply sounds like you may have another fault now on a diffrent board i wonder if you can run the test patterns if lg has this feature.
                        • jason424
                          • Dec 2015
                          • 187
                          I feel like a complete moron (what would the equivalent be in the UK? berk?).
                          I went to go test the board settings again and plugged it in and turned it on. This time I flipped it up against a wall to see the full screen instead of just seeing the edge from underneath when it's hanging off the edge of the bed. Well....it turned on. And the "No Signal" notification was floating around the screen. I obviously didn't see it when it was just the lower edge and assumed the panel was off. So the replacement board from the UK was good and the TV works as it did previously with no image color issues or speckling.
                          But, as this is my first plasma I've worked on/replaced board, is there any adjustment to the Va/Vs voltages that should be done before moving this to my parents house?
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            • uk
                            #113
                            moron a good word we do use that as well in the uk and as this is a replacement power supply i would check all voltages match the panel sticker if not you can carefully alter them too match but mark the pre sets first with a marker pen just incase altering the voltages causes screen issues (dots etc) and turn them really slowly as dont want too go high and risk blowing parts.
                            • jason424
                              • Dec 2015
                              • 187
                              Yeah they are real close so I don't think I'm going to monkey with them. A big thank you to you and everyone else that stuck through all the pages of posts to help me. I really appreciate your kindness and patience while I try to learn.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                #115
                                yes being that close i wouldnt adjust them if causing no screen issues and glad the psu replacement fixed the issue sometimes even the best of engineers get stuck and have to replace boards as your had lifted traces/pads was probably the best way forward anyway.
                                • jason424
                                  • Dec 2015
                                  • 187
                                  Well and since that old board is done now...I can practice on removing components without ruining traces/pads for future projects.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    #117
                                    some times you cant help lifting the traces but you will get better with practice its just getting the correct heat not too long or too little and adding fresh solder first in my opion always helps with removal.
                                    • bffargo
                                      2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
                                      by bffargo
                                      LG 60PB66550 NOV 2014
                                      PSU: EAY63168603
                                      PCB: EAX65359531 2013.11.01 Rev:1.0
                                      Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
                                      Symptom:
                                      While watching, just went black and started clicking relay every few seconds.
                                      Initial diagnosis:
                                      Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
                                      Deeper diagnosis:
                                      Pulling pins #1/#2 (Blue/Grey) from the connector housing...
                                      09-09-2022, 07:34 PM
                                    • Sisko
                                      Onkyo-593 No power and now clicking sound
                                      by Sisko
                                      Hi all!!
                                      Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                      10-03-2025, 02:18 PM
                                    • B0r1s
                                      Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                      by B0r1s
                                      PSU - BN44-00878A
                                      Symptoms:
                                      The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                      A weak clicking sound was coming from the transformer.
                                      Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                      Progress:
                                      After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                      01-17-2023, 04:58 PM
                                    • novak2
                                      Panasonic th-42px60en plasma TV takes time to turn on and make clicking noises
                                      by novak2
                                      Hello there,
                                      I recently bought a Panasonic th-42px60en plasma TV second hand. The problem is :
                                      The TV takes time to turn on from cold (being unplugged from the night for example), it tries to turn on with the clicking sound, then shuts off, then retries and so on. The TV is still working, just it takes time to boot.
                                      From what I've read it seems to be bad capacitors on the power board, but I just want to see if anyone had the same problem with this TV.
                                      Thanks in advance.
                                      09-25-2020, 02:34 PM
                                    • slimmy182
                                      [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                      by slimmy182
                                      Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                      I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                      Looking on google I found this:...
                                      01-14-2023, 11:55 AM
