Sony kdl-60W630B 5 Blink Error
  • tigton
    • Dec 2016
    • 4
    Hi All. Sony kdl-60W630B giving me the 5 red blinking light error.
    PS seems good, output from it is okay. I changed the TCON board already with no change to problem.
    Everything hooked up as it should be: 5 red blinking lights
    TCON disconnected from main board:Green light as it should and backlights come on as they should, no images
    TCON disconnected from panel (either/both of the ribbon cables): 5 red blinking lights.
    Anyone have suggestions on what to try? I'm thinking the panel is simply dead.
  • budwich
    • Jul 2015
    • 3097
    Re: Sony kdl-60W630B 5 Blink Error
    History? what happened to get to where you are?
    • tigton
      • Dec 2016
      • 4
      Bought it as is for $75. I've had some good luck fixing tv's in the past. Can't figure this one out
      • budwich
        • Jul 2015
        • 3097
        :-( swapping cards might not have achieved much IF the "new one" met with the same issue as the old one. :-(
        Check both for blown fuses and go from there.
        Of course, if you want more help, read the "hints" about posting at the start of the forum and what info AND pictures you need to get.
        Since, it has an "unknown history", you should likely do a good inspection of the backside / board / panel looking for ..... bad things like "water marks"... as people seem to thing a "little window washing" can't hurt anything... :-) look around the bottom panel / boards for glues.
        • martino
          Not so "senior"
          • Aug 2013
          • 997
          • canada
          Agreed,both tabs disconnected from panel and still 5 blinks,tcon disconnected,green light.
          I'm thinking you bought a defective t-con board
          Proud owner of dozens of broken TV's and many,many,many boards.
          Our website and passion:http://hollenhundshepherds.com/
          • tigton
            • Dec 2016
            • 4
            If the panel was bad, wouldn't it be acting the same way it is now even with a working Tcon?
            • Hamie
              • Apr 2014
              • 1383
              Is the purchased t-con from the exact model of the tv or is just a matching board.
              Their are eeproms on the t-con even if the board number matches it must be programmed for your panel.
              • BigTV
                • Dec 2017
                Hello Tigton, did you find the fix for your Sony KDL-60W630B, I'm having the same issue. 5 red blinking lights?
                • iglitare
                  by iglitare
                  09-04-2025, 07:13 AM
                • YasaCh
                  Sony kdl 40p5500 red light keeps blinking 3 times
                  by YasaCh
                  Hello...
                  my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                  i opened the back cover no sign of damage on the powery suply or motherboard
                  when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                  another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                  07-07-2025, 11:53 AM
                • BakaMonogatari
                  LG 65UJ6300 no backlight unless TCON disconnected.
                  by BakaMonogatari
                  Full model of the TV is 65UJ6300-UA.BUSYLOR. TV was given to me by a relative as non-operational so I'm trying to get it working so I have a nice cheap upgrade for my living room. This is my first TV repair so if it sounds a little like I know what I'm talking about, I don't.
                  TV turns on and has audio, but backlight doesn't turn on. Getting 230v from LED+ to chassis. Also can't see anything with flashlight test. Another forum suggested I replace the LED strips because that's the most common failure on LG TV's and the flashlight test doesn't always show results.
                  11-04-2021, 12:36 PM
                • TerraPhantm
                  Sony A8H to A80J mainboard upgrade possible?
                  by TerraPhantm
                  I have a Sony 65A8H. Always bothered me that it doesn't have HDMI 2.1. I noticed the A80J board appears quite similar. And comparing some wiring diagrams in the service manuals (albeit A9G vs A90J since I couldn't find the A8/80 manuals), things appeared quite similar. And my understanding is the panels between the two TVs are more or less the same.
                  So I decided I'd experiment a little bit.
                  I bought an A80J board. Left the speaker connection unplugged because it doesn't fit. Changed the power connector to fit the new board. Plugged in everything else.
                  When...
                  08-15-2023, 08:10 AM
                • kca
                  by kca
                  Hello all ~
                  08-31-2025, 06:38 AM
