Vizio E422VL Stuck on Logo OR Horizontal lines Gradient
  • danskelly
    • Jan 2016
    • 15
    Hey all!
    I was given this TV. I was warned of its problem. When I brought it in, I plugged it in, and turned it on. The logo went white, Saw the V logo, and then everything functioned normally. I went through the menus, and inputs, etc. All looked fine. So, I did a Factory Reset on it so I could start from scratch.
    Ever since the Factory Reset, the thing will not get past the V logo on power up.
    Now, I have done my due diligence, and it seems that the general consensus is to replace the EEPROM. I'm not quite comfortable with my ability to solder small objects, but I'll give it a try as long as I have a backup plan.
    With the TV, my friend gave me a Mainboard that he bought on eBay, but he didn't read the print, and it is listed as "As-Is, NOT WORKING". I installed it anyway, just to see what the extent of its problem was.
    Good news!! It works..... sorta. It doesn't have the same symptoms as the original Mainboard, and I can live with the symptoms it does show. But, I'd still like to get your input:
    The image is there, and the colors are good. But, there are horizontal lines tat gradient from left to right.
    The very left-most of the screen is perfect. As you look to the right, you start seeing horizontal lines begin to appear, and if you look at the right-most edge the lines are clear. (Seen in pictures.)
    Now, I can live with this, but I'm curious. Is this fixable?
    Thanks!
    DAN
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Vizio E422VL Stuck on Logo OR Horizontal lines Gradient
    Did you try to reset the set with the original main board using the remote to see if you could get past the logo.
    http://www.wikihow.com/Reset-a-Vizio-Remote
    • bikerbuddy
      • Jun 2011
      • 134
      Looks like the main board your friend bought from ebay were starting to go bad also , On your original board you do have a corrupt eeprom , the cheapest way to start is to replace the eeprom on your original board and see , 2nd option is the tcon board , I am not an expert but have done some eeprom work before and came out successfully every time , great forum i have learn so much here.
      • danskelly
        • Jan 2016
        • 15
        I did try to reset it using various methods found on BadCaps... But to no avail.
        I've tried unplugging the set, and holding the power button for 60 sec, and them plugging back in. Same symptoms. :-/
        I've tried the remote thing you sent above, still no solution.
        • danskelly
          • Jan 2016
          • 15
          Okay! It's fixed!
          It turns out that I hadn't seated one of the ribbon cables into the second Mainboard properly, causing the horizontal lines in the display.
          So, the Mainboard that had been labeled as "NOT WORKING" is actually working fine, and I just went too fast to install it.
          Thanks all!
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Well that's a stroke of luck. Well done.
            • mmartell
              • Oct 2013
              • 3189
              May have been listed as "not working" because of the same failing eeprom. Keep an eye on it.
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
              • Ihandyrepair
                Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                by Ihandyrepair
                Hi guys
                I just started fixing 4k TV few months ago. so I am still learning a lot
                I got this tv from friend complaint is ghosting or horizontal lines on image.
                never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                then it started to show the ghosting white image.
                I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                it has 3 thin small boards at the bottom of the...
                12-05-2022, 04:18 PM
              • ggil44
                Sony XBR-65X750D Horizontal lines bottom of screen
                by ggil44
                Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                05-30-2023, 07:51 PM
              • noisykid
                Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                by noisykid
                5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                12-30-2024, 07:15 PM
              • x_orange90_x
                Samsung UN46C8000XFXZA Horizontal lines
                by x_orange90_x
                I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
                I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
                07-15-2023, 05:06 AM
