Samsung UN40H6203AFXZA power light blinks; no video; to BL need power board schematic
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Samsung UN40H6203AFXZA power light blinks; no video; to BL need power board schem
    pity the pcb was damaged would of been cheaper to by new leds and replace all of them in one go.
    • ngth82
      • Jul 2015
      • 541
      At the same time, do you, or anyone else have cross reference information on the LEDs for a LM41-00001V light string? I don't have a good reference as to how the LED pads should look like since it's all burnt up. I'm assuming the replacement LED should just have two pads similar to: http://www.lumileds.com/uploads/402/DS203-pdf
      The PCB is charred, but I think it still can be salvaged ... just need to really clean up the damaged section or cut it out entirely.
      -Thomas
      I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
        It needs to have If rating around 300~400mA range (not the peak pulse rating), 1W LED should be the one to get..
        • ngth82
          • Jul 2015
          • 541
          I returned the TV to the owner as-is. It works for now, so we'll just let it be.
          Thanks for the support!
          -Thomas
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • C152Heavy
            Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
            by C152Heavy
            Summary for TL-DR readers:
            • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
            • Have obtained Samsung schematic & service documents - Can upload if helpful.
            • Have read ALL applicable threads
            • C1818 and CP820 replaced as low hanging fruit
            • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
            • VCC pin (18) of PFC...
            01-11-2023, 02:53 PM
          • Destroyer-Br
            [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
            by Destroyer-Br
            I'm working on an Acer Nitro 5 unit with the following specs:
            • Motherboard: LA-J871P Rev: 1B
            • Model: Acer AN515-55-59MT
            • S/N: NHQ7JAL00403906A973400
            • SNID: 03902728734
            Initial Issue
            The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
            After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
            04-17-2025, 08:18 PM
          • Nicktronic
            Samsung Power Supply Board BN44-00874F
            by Nicktronic
            Hey everyone,
            This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
            Anybody...
            03-17-2025, 06:20 AM
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
