SONY XBR-65X850A Panel
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Picked this one up for next to nothing..Owner was told that issue was display panel. Supposedly someone took it to a tech who replaced a board, said TV worked but new board was running hot so they faulted the panel. Going to open it up and check things out. More pics to come with some voltage measurements.
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Re: SONY XBR-65X850A Panel
    I have had several 40"+ Samsungs with this condition that was caused by bad gamma chip on t-con board..
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Looks like an Led set which wouldnt use the As15, get us some pictures of the boards bud
      • ljintexas
        LJinTexas
        • Jan 2015
        • 669
        WOW! What a T-con board!
        If anyone replaced anything, it was the T-con. The foil on the sides has been removed and re stuck and there is adhesive residue on a harness where tape was removed and put back a half inch down the harness. Nothing else looks like it has been disturbed.
        From what I gathered.."a board" (not the A board per say)was replaced but removed because of heating up while working. But the set worked with the new board..they faulted the panel.
        Thanks for your time Reecey
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Wow is that 4K ? Also heating the Tcon fixes it ?
          • ljintexas
            LJinTexas
            • Jan 2015
            • 669
            Yes, it is an early 4K. What I was told was that a tech replaced one of the boards and the TV worked normally. They were concerned that whatever board was replaced was running too hot so supposedly, they reinstalled the old board and said the panel was bad. I do not know how much truth there is to that. I can tell you someone has removed the T-con from the way the foil tape on the cage that goes over it was re-installed.
            My experience with 4K thus far has been one smps that was bad and one "enhancement board" which I think is called an A board? It was obvious on both where the source of the heat was.
            Thanks Reecey
            • ljintexas
              LJinTexas
              • Jan 2015
              • 669
              I ordered a T-con board as it was cheap..The main board seems to be made of unobtainium!
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Yeah I would say replace the Tcon looks like one of the gamma reference drivers has failed causing the panel not to be driven correctly.
                • ljintexas
                  LJinTexas
                  • Jan 2015
                  • 669
                  I will post results when parts arrive. Reecey, as always, I appreciate your input. Hard for me to believe a set of this caliber and age has a bad panel. Less than 3 yrs old, low usage, was in climate controlled storage for over 18 months. Previous owner stated that he had Best Buy (of all people) come and "calibrate" this set. Within 6 months it failed. May be no correlation, but just seems like a coincidence.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Its alright I just had a 52" Samsung 105 hours use and one of the ccfls failed will make thread. Keep us updated.
                    • ljintexas
                      LJinTexas
                      • Jan 2015
                      • 669
                      Thank You Sir
                      • ljintexas
                        LJinTexas
                        • Jan 2015
                        • 669
                        Replaced T-con with a module from Tristatemodule..Set is working normally. After 30 min. the larger ICs on the T-con were warm to the touch..not hot, but warm. Temp in my shop at the time was around 50F. Buttoned it up and ran it for several hours...no issues. Do those T-con ICs typically run warm?
                        LJ
                        • howardc64
                          by howardc64
                          07-24-2025, 05:17 PM
                        • m1ch43lzm
                          by m1ch43lzm
                          05-12-2025, 08:37 PM
                        • jb_Bak
                          by jb_Bak
                          CN6401
                          Pin 01 NC
                          Pin 02 NC
                          Pin 03 "BL_ON": 0V
                          Pin 04 "N/C"
                          Pin 05 "STBY 3.3V": 3.5V
                          Pin 06 "GND": N/C
                          Pin 07 "AC_OFF"...
                          09-27-2021, 04:52 PM
                        • advant
                          by advant
                          02-03-2020, 12:25 AM
