Sharp LC32-SH340SE/V 17MB60-4
  • advant
    by advant
    02-03-2020, 12:25 AM
  • rimwall
    Sony KD-65x7500D - double image - Tcon or Panel?
    by rimwall
    This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
    I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
    11-18-2025, 02:09 AM
  • moltensolderlabs
    Sharp LC-52E77UN TCON activation WITHOUT motherboard. I2C reverse engineering help?
    by moltensolderlabs
    Hi everyone. [Sorry for the long, detailed post in advance].
    I have a Sharp LC-52E77UN which randomly shuts down--could be within 15 minutes, could be 40 minutes, over 1 hour, it's unpredictable. From reading the service manual, I was able to get into service mode (where the K is displayed), and found the following error flag toggled: "04 Initial Communication Error 4 -- Error reason: To the communication setting reception," which, from contacting an eBay TV repair store, I was told is caused NOT by a bad TCON (which was my first guess), but rather the motherboard....
    10-09-2020, 12:01 PM
  • jason123
    ASUS PG27V Rolling Image - TCON?
    by jason123
    Hi there,
    My son's gaming monitor started having rolling image (vertical roll - See Video) similar to vertical sync issue, or T-CON problems in TVs. Has anyone see this? is it fixable or a throw away?
    I haven't even opened it up yet. Does it have a T-CON? Help is appreciated.
    It does this even with the monitor not connected to a computer / graphics card....
    11-01-2025, 05:41 PM
  • jason123
    Hisense 65R6E3 double-image / horizontal strips - TCON?
    by jason123
    Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
    07-19-2025, 08:07 AM
