Standby light only LG LG42LB5500
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Standby light only LG LG42LB5500
    Originally posted by reeceyburger123
    oven is for food not pcbs.
    ....Yes a new main Bd did the trick....Good Job..
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Its just like putting my cat in the oven because it keeps shitting around the house
      • Michael Long
        No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
        by Michael Long
        I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
        Dead / No Power / No Standby Light results after power company had three
        consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
        After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
        09-13-2022, 06:55 AM
      • ChristianBr01
        LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
        by ChristianBr01
        I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
        The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
        What I already found is that the 12.8V are not an the connector to the main board connector to the power...
        04-23-2025, 01:48 AM
      • stylishconsultant
        un60j620dafxza - Samsung No Display Problem
        by stylishconsultant
        Hi All,
        Need help.
        I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
        So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
        problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
        might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
        09-04-2024, 03:26 AM
      • brithepi2k
        Sony KD-65XE8596 no standby light
        by brithepi2k
        I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
        cheers...
        09-06-2025, 02:22 PM
      • AleMonti
        LG 55EG910V - no power and no standby light
        by AleMonti
        I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
        I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
        The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
        After checking the basics I did the following:
        • I measured all voltages and as expected the only active supply is the 3.5V standby. It
        11-04-2024, 05:02 PM
