PS50Q96HD Panel Failure Blowing Boards ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Im about to physically flip out in a minuet. This 50" Shitsung is being a total pain in the ass. Originally came in with blown upper buffer and Ysus. Ive fixed over 20 of these by now so nothing new to me.
    Sorted both, tested Ysus before hooking up the buffer all voltages correct. VSC fine etc, Xmain also tests fine voltage wise. Plugged in buffer and bang goes my replacement Ic even though it tested fine and there was not any solder faults.
    After replacing it again and retesting everything which seemed fine I decided to put the Ysus, buffers, xmain and control board in another panel (Q97) which had good sustain boards just psu fault and put the ones out of that into the Q96 and it blew up the Ysus and buffers again wtf ?
    Is my PDP in the Q96 failed ? Its not cracked and there are no evident line shorts but the boards were fine and now the Q96 ones that I repaired are working fine too. Any ideas before the set leaves the house out the window ?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: PS50Q96HD Panel Failure Blowing Boards ?
    Panel shorting....you did everything correctly, twice......out thru the window... :-)
    • syaoran123
      • Jun 2014
      • 178
      Stand and power supply can be sold and are in high demand for that model. The igbt RJH3047 are salvageable from the x and y mains, and can be used to replace panasonics failing rjp30h2a and 30f131.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Update, still got the set going to have a good play soon. Fixed up another Ysus and buffer. Will be scoping all waveforms later and seeing if they are correct then will hook panel up.
        • steviewonder
          • Dec 2013
          • 183
          • england
          I have had this problem...a very close inspection has revealed a blown (black) pixel on the screen.Had around five sets now,over two years,with the pixel issue.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Cheers buddy, I trashed this junk today. Almost blew another buffer, few good punches finished it for good never bothered to look for black pixels. Thanks for the post first time Ive had this on these.
            • mecha1166
              KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
              by mecha1166
              KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
              11-25-2024, 05:22 PM
            • CapLeaker
              Dell ATX PSU won’t start, but forcing it works fine?
              by CapLeaker
              Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
              Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
              10-28-2024, 06:59 PM
            • emil_t
              RTX3090 working fine but fans not spinning
              by emil_t
              Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
              04-12-2024, 06:54 AM
            • PlasMatt
              LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
              by PlasMatt
              I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
              09-20-2025, 06:50 PM
            • legg
              LG 42PC3 buffer output doesn't follow YSUS
              by legg
              LG42PC3D -UD originally with green lamp but no display or audio.
              Owner says was working, then went 'pop'.
              All 5V caps bulging. replaced.
              All PSU output voltages within spec but -Vy is low on YSUS.
              One of three parallel fets between SUS_OUT and SUS_DN is zenering,
              eventually shorts DG. Replaced all 3 - -Vy now OK.
              Y scan buffer test point does not follow YSUS output below -50V
              Note: This unit seems to expect YSUS output to park at -Vy in between
              drive signal pattern periods. A replacement drive signal board confirms this....
              11-18-2021, 11:49 AM
