longer it runs the fewer and narrower the lines get is this ribboN???
KDL-52W3000 SONY PIC longer it runs the fewer and narrower the lines get.
Re: KDL-52W3000 SONY PIC longer it runs the fewer and narrower the lines get.
Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem -
What lines, vertical, horizontal, diagonal, picture visible? colored lines or what?
So--What lines, no info = hard lines!
--You want help--you gotta put out and take pics of the fault and the internals of set--We are good--But we Aint Mind-readers!
Total Guess with no pics or other data, Panel fault, not fixable.TELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM!Comment
Total Guess with no pics or other data, Panel fault, not fixable.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/Comment
Yup--Just bugs me too. I think--Why should I bother--if they can't be arsed then neither can I!TELEFIX
Another thing is people making new threads with out researching at all and there is already loads of threads about the same issue !Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
This is due to people's inherent general lazyness--These days they need spoon-feeding, in fact, if they could--they would get you to repair it for them--and make you feel like they are doing You a favour for allowing you to do so!TELEFIX
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by SysengThis sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...-
Channel: BIOS Requests ONLY!
by Stanley1843Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
by jeyoung12Hi all
I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
So....i don't know what end of the C ribbon to work with... -
by DrvLikHellHello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
The... - Loading...
