Panasonic LCD tv goes into standby and won;t display a picture
  • Acerman
    • Oct 2016
    • 30
    • United Kingdom
    This Tv is a Panasonic tx42a400. It will not display a picture or sound. The tv powers on but the green power LED quickly turns to a red flashing LED and the tv stays on standby. There are some signs of life on the screen initially soon after powering on. You can clearly see backlight activity , but this soon goes off and then the tv shuts down to standby. I have changed the power board as I thought that this was the cause of the problem. Also used different cables etc. I now suspect the main av board and wanted to know if anyone can suggest some voltage testing to check the av board before I buy a replacement av board.
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Panasonic LCD tv goes into standby and won;t display a picture
    If you could post some photo's of your boards and how they are interconnected would be a good starting point.
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      How many blinks?
      TELEFIX
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Check my thread out likely led failed:
        https://www.badcaps.net/forum/showthread.php?t=54714
        Also do some research yourself on how to test voltages the forum is full of advise in previous threads.
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          Originally posted by reeceyburger123
          check my thread out likely led failed:
          also do some research yourself on how to test voltages the forum is full of advise in previous threads.
          +1
          • Acerman
            • Oct 2016
            • 30
            • United Kingdom
            Alistair e. The tv just seems to blink repeatedly without a pause.
            • Acerman
              • Oct 2016
              • 30
              • United Kingdom
              dick barton, I will get some photos on here asap if I can.
              • Acerman
                • Oct 2016
                • 30
                • United Kingdom
                I get the basic principle. Use the metal back chasis of the lcd panel as ground and then use the red probe to test the voltage.
                • Acerman
                  • Oct 2016
                  • 30
                  • United Kingdom
                  Thanks reecyburger. Very useful link. SO you think, maybe a faulty led strip or individual led. You may be right as I have now repaced both the main board and the psu board and the fault persists.
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    What's the part number printed on the power supply. It's too out of focus to see anything clearly.
                    • Acerman
                      • Oct 2016
                      • 30
                      • United Kingdom
                      Part number for the psu is TNPA5916
                      • dick_barton
                        • Aug 2015
                        • 6642
                        • Wales
                        Assuming that your power supply is OK, do the backlights come on and remain on if you power up with the mainboard disconnected.
                        • dick_barton
                          • Aug 2015
                          • 6642
                          • Wales
                          Does this set also have a led driver board??
                          • Acerman
                            • Oct 2016
                            • 30
                            • United Kingdom
                            Yes, it does have an led driver board. Have tried changing it as I have a spare, but made no difference.
                            • Acerman
                              • Oct 2016
                              • 30
                              • United Kingdom
                              No. The led goes red and it goes to standby, but the backlights definately don't come on. This was with the lvds cable disconnected from the main board.
                              • dick_barton
                                • Aug 2015
                                • 6642
                                • Wales
                                To check the backlights then disconnect the mainboard from the power supply and connect PS_ON (Power On) to Standby Voltage using a 1K resistor, and also BL_On(backlight on) again to Standby Voltage using 1K resistor.
                                • Acerman
                                  • Oct 2016
                                  • 30
                                  • United Kingdom
                                  Have reconnected the lvds to the mainboard, but now have no backlight activity atall. At first, when this problem started the backlight came on for about 1 second shortly after powering on. Now there is nothing and the tv is on standby with the 1 repeating led flash.
                                  • dick_barton
                                    • Aug 2015
                                    • 6642
                                    • Wales
                                    What results did you have regarding my earlier post #16
                                    • Acerman
                                      • Oct 2016
                                      • 30
                                      • United Kingdom
                                      Haven't done this from 16. I don't have the 1k resistor. Have just reconnected everything.
                                      • Acerman
                                        • Oct 2016
                                        • 30
                                        • United Kingdom
                                        Thanks for the help but I am not sure I need to test further. The link from reecyburger shows exactly the same symptoms in another tv from the same series. Also, mine blinks once red followed by a pause. One blink means backlight issue according to Panasonic. I need to decide whether to strip down the panel or not. I am wary of doing that , as I may damage the lcd beyond repair by dismantling everything. It may be worth doing though.
                                        • brithepi2k
                                          Samsung UE75TU7020k No picture, Standby blinks 2 times
                                          by brithepi2k
                                          My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
                                          04-23-2025, 10:05 AM
                                        • BobbyMJ
                                          Panasonic TC-P60S30 - no standby voltage
                                          by BobbyMJ
                                          Hi All,
                                          Wanting to learn some electronics repair skills.
                                          I found a non working Panasonic TC-P60S30 and this is my first project / attempt.
                                          So far I have found a blown cap on the main power supply board.
                                          After replacing it there's still no standby power.
                                          Poked around and found a resistor on the PSUB power supply board that measures open.
                                          An online resistor calculator shows this is a 93k ohm resister.
                                          My questions:
                                          Is that correct, 93k ohms?
                                          Is it a fusible resistor?
                                          Lastly, how do I know what wattage?...
                                          05-14-2025, 06:42 PM
                                        • FZG
                                          Panasonic AG-1000B VHS player with bad picture quality
                                          by FZG
                                          Hello!
                                          I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
                                          Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
                                          I want to know, is this something that could be solved by recapping or is the video head likely gone?
                                          Also, what mechanism is this?
                                          Any feedback is appreciated!...
                                          05-06-2024, 07:16 AM
                                        • Bazfletch3
                                          Panasonic TH-65FX800A backlight LED's working but picture is very dark
                                          by Bazfletch3
                                          Hi all
                                          While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
                                          I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
                                          From there I envisaged that the backlighting wasn't working, however...
                                          01-08-2024, 10:18 PM
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
