Panasonic LCD tv goes into standby and won;t display a picture
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Panasonic LCD tv goes into standby and won;t display a picture
    Originally posted by Acerman
    Thanks for the help but I am not sure I need to test further. The link from reecyburger shows exactly the same symptoms in another tv from the same series. Also, mine blinks once red followed by a pause. One blink means backlight issue according to Panasonic. I need to decide whether to strip down the panel or not. I am wary of doing that , as I may damage the lcd beyond repair by dismantling everything. It may be worth doing though.
    Take your time stripping it down. There's lots of Youtube video's on how to. Also do not mix up the order of the diffuser sheets when you lift them out from behind the LCD panel so that they go back in the correct order. A few people have made this mistake.
    • Acerman
      • Oct 2016
      • 30
      Originally posted by dick_barton
      To check the backlights then disconnect the mainboard from the power supply and connect PS_ON (Power On) to Standby Voltage using a 1K resistor, and also BL_On(backlight on) again to Standby Voltage using 1K resistor.
      Dick Barton , I understand what you are saying here. You mean use the 1k resistor with a multimeter to test the individual led's? I understand that you have to reduce the voltage by using a resistor so as not to blow the led's.
      I now have some 1k resistors and I have decided to strip the panel down so that I can get to the led strips and then I will test each led with a multimeter and a 1k resistor.
      Many thanks. I can see where you are coming from.
      I will update once the panel is stripped down. Not much time this week, so there may be a delay.
      • brithepi2k
        Samsung UE75TU7020k No picture, Standby blinks 2 times
        by brithepi2k
        My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
        04-23-2025, 10:05 AM
      • BobbyMJ
        Panasonic TC-P60S30 - no standby voltage
        by BobbyMJ
        Hi All,
        Wanting to learn some electronics repair skills.
        I found a non working Panasonic TC-P60S30 and this is my first project / attempt.
        So far I have found a blown cap on the main power supply board.
        After replacing it there's still no standby power.
        Poked around and found a resistor on the PSUB power supply board that measures open.
        An online resistor calculator shows this is a 93k ohm resister.
        My questions:
        Is that correct, 93k ohms?
        Is it a fusible resistor?
        Lastly, how do I know what wattage?...
        05-14-2025, 06:42 PM
      • FZG
        Panasonic AG-1000B VHS player with bad picture quality
        by FZG
        Hello!
        I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
        Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
        I want to know, is this something that could be solved by recapping or is the video head likely gone?
        Also, what mechanism is this?
        Any feedback is appreciated!...
        05-06-2024, 07:16 AM
      • Bazfletch3
        Panasonic TH-65FX800A backlight LED's working but picture is very dark
        by Bazfletch3
        Hi all
        While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
        I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
        From there I envisaged that the backlighting wasn't working, however...
        01-08-2024, 10:18 PM
      • Tr0ll
        by Tr0ll
        Original T-con:
        First replacement T-con:
        10-07-2023, 07:48 PM
