Polaroid LE-32GCL firmware needed!
  • steviewonder
    • Dec 2013
    • 183
    • england
    Just wondering if anyone has a dump,or usb file for this parcel?...
    mainboard is one of those horrible mutant affairs, TP.SIS231.P83.
    I have tried various files from the net,none seem to work properly.
    Maybe someone has the dump of files they could kindly supply?
    best wishes,
    steve
  • bikerbuddy
    • Jun 2011
    • 134
    Re: Polaroid LE-32GCL firmware needed!
    Many times over I would remove the eeprom from the main Board and see if I can get a read from it ,If you do then get your self a new eeprom and do a write on it and place it back on the board and see how it work.
    good luck. I have done it before .
    • Daniel Larsson
      Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
      by Daniel Larsson
      My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
      I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
      During these seconds the function button is not working...
      08-13-2025, 10:29 AM
    • EduCabral
      [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
      by EduCabral
      I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
      While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
      🔧 Details:
      • Model: YT-M06
      • Interface: Pioneer 1
      • MCU: Fujitsu MB89F202
      • Goal: Find a valid .bin firmware file or memory dump from a working unit
      I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
      07-15-2025, 12:26 AM
    • Daniel Larsson
      Firmware file for Marantz NR1501 needed
      by Daniel Larsson
      I picked up a Marantz NR1501 that the seller said did not produce any audio, but was starting up just like normal. This was indeed the case and the hunt for damaged components started.
      After confirming all voltages and replacing all caps on this godforsaken HDMI-board I finally got sound from the AUX input, but all digital inputs are still dead.
      The service menu shows no DSP version so I desoldered IC1604 that should have the serial flash DSP firmware on it and made two dumps that turned out identical.
      The content of these seems to be useless as far...
      05-23-2025, 04:11 AM
    • neo2010
      Lenovo X1 Carbon Gen 2 Touchscreen Firmware needed
      by neo2010
      I accidentally flashed the wrong firmware to my Lenovo Laptop Touchscreen. Now it is not recognized anymore in Windows 10. With Linux, I get the Device Listed as ELAN 04f3:000b USB device. I have modified the original Lenovo Flash Tool and tried other Firmware bin files but without success.
      The screen is the WHQD version. Can anyone provide a firmware bin file to reflash the touchscreen controller? As it seems that the controller is in recovery mode.
      Thanks in advance
      05-23-2024, 08:04 AM
    • gkoukoul
      TV Felix FXV-4221 - firmware needed
      by gkoukoul
      Hello!
      I have a Felix TV that turns on, shows the "FELIX" logo then shows a "WISDOM SHARE" message and doesn't do or respond to anything else.
      I'm assuming a firmware flash will fix it.
      I can't find the firmware file though, anyone has it please?
      11-12-2024, 12:02 PM
