I've got a sanyo/funai model fw32d06f. Board is a ba4afsg0201. Basically dead. No power. No standby. I was told it took a "power hit". I have continuity at the fuse and all the caps look good. No bulging. Although I haven't gone through each one with my cap tester yet. I'm getting 120v up to the diodes on the hot side. Just looking for some advice on where to go next? Pictures on the way.
sanyo/funai fw32d06f dead
Tags: None
Re: sanyo/funai fw32d06f dead
This link has a fairly good pic ...
http://www.tvpartscentral.com/funai-...-for-fw32d06f/
... given how cheap these are I might just order the board but I'd still like to take a crack at repairing the current one regardless.
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
by double_DDHi all,
As the title suggests, how can I be sure that my EC chip is really dead?
I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard... -
by Michale32086I have Sanyo 55" TV that randomly shuts off..
Sometimes it will stay on for 5mins or so, sometimes it shuts off after a min or two...
When it DOES stay on, it works fine...
All things being equal, would it be more likely a POWER Board issue or a MAIN Board issue???
Thanx in advance...... -
Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
State I got it in:
Squealing from the PSU
After logo I get a blank screen
After 10 seconds of having a blank display w/ backlight the TV dies
Give it 7-10ish seconds again and it starts to bootloop.
What I did so far:
Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
Checked all voltage rails:
5VSB - 4.8V
AMP+13V - 14.4V
13V - 12.98V (in manual 12V)... -
by disorderhello guys,
i need help to repair a edm-033 ps2
history : as always hdmi port and usb ports destroyed after unplugged
after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
so i changed it
now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
i don't see any projection of liquid metal on pcb.
... - Loading...
