Toshiba 47L7200U TV with thin vertical lines
  • lucky13
    • Aug 2007
    • 412
    Friend has a 2012 made Toshiba TV and all of a sudden developed these vertical lines top to bottom, all across. The colour is also off too.
    Here are a couple of pictures.
    I am not a TV guy but have dabble enough with bad caps and he asked me to take a look.
    Is this panel problem? Or main board problem?
    Doesn't sound like power supply problem to me.
    I have not opened it up yet to poke around.
    Thanks for any tips.
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Re: Toshiba 47L7200U TV with thin vertical lines
    Looks like a main board or T-Con issue. Does this TV have an LG panel or Sharp?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      I agree if an Lg panel it will be the mainboard if its a Sharp panel will be Tcon.
      • lucky13
        • Aug 2007
        • 412
        Thanks for the reply guys.
        Since I have not picked up the set from my friend's place yet. I don't know what panel is inside.
        Maybe I can search for the Special code to enter the service menu and find out what panel is used?
        So panel is panel or T-con board?
        Main board could also mean bad news as not so much Toshiba parts I find.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Check model on google.
          • aaronwt6
            • Apr 2013
            • 855
            • US
            +1
            And yes, the main boards are very tough to find for this one. My guess is that the TV has an LG panel based on what shopjimmy shows:
            http://www.shopjimmy.com/toshiba-750...r-47l7200u.htm
            That being said, it may be worth waiting to see if one pops up on ebay at a reasonable price. The only thing I see is a traded in service for nearly $200.
            You can also check with pts electronics and see if they offer a repair service for your main board.
            • lucky13
              • Aug 2007
              • 412
              Found youtube video showing 3 different ways to get into Service Menu.
              Unfortunately friend said none of them works.
              I told him the one for LCD should work but he said he tried many times:
              Press MENU on R/C
              Highlight PICTURE icon
              Press 9, 3, 0, 1
              and service menu should appear.
              He also tried the other mentioned methods to no avail.
              Looks like I have to go over his place to take the back off.
              So, if the main board is the issue, is it one of those BGA problem?
              • lucky13
                • Aug 2007
                • 412
                Panel is by LG.
                • Stanley1843
                  by Stanley1843
                  06-29-2024, 11:54 AM
                • polaro
                  Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
                  by polaro
                  Greetings,
                  I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
                  08-27-2022, 08:46 AM
                  HP Mobile Thin Client mt44 Mobile Thin Client 3JG86EA Mobile thin client Specification for Upgrade or Repair
                  This specification for the HP Mobile Thin Client mt44 Mobile Thin Client 3JG86EA Mobile thin client can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the mt44 Mobile Thin Client 3JG86EA boardview and mt44 Mobile Thin Client 3JG86EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                  09-06-2024, 06:50 AM
                • Falki
                  Colorful LCD Vertical Lines on Samsung ue55es8090
                  by Falki
                  Hello there, ive recently found an older 55inch Samsung SmartTV.
                  A similar issue has been posted as well but also with no actual response ...
                  08-12-2025, 04:19 AM
                • visionbluedemon
                  Help. Sony kd-65x85dj vertical lines
                  by visionbluedemon
                  First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                  Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                  tried blocking LC lines too, but same results
                  is it lcd panel issue or tcon board issue?...
                  07-25-2025, 04:56 AM
