Panasonic tc-p50vt25 problem, help!
  • Ncdude
    • Nov 2016
    • 6
    • usa
    My TV has started some strange behavior that I need some help troubleshooting. I turn it on and start to watch tv and then with no warning you can hear the tv click and the screen goes off but the red led on the front stays on and never blinks. Sometimes the tv recovers and has an error message "error occurred and was recovered" or words to that effect. Other times the screen comes back on and if you push the volume button on the remote it goes off or it recovers and sits for 20 seconds and goes off. No matter the behavior the red led on the front never blinks. I hope this is enough info for someone to make a suggestion. Very frustrating for sure.
    Thanks for the support,
    Scott
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic tc-p50vt25 problem, help!
    Scott
    Yeah, sounds like mainboard(A-board) however this being a VT also has a D -board. I've heard of this before and also I picked up a 2010 U series with the same issue and it was the A-board I suspect heat and broken BGA solders.
    If you did not have the D board I would say 100% A but I still think it's A but there's that chance I may be wrong. D failure I've read of 1 blink or coloured vertical blue and red bars across the screen.
    http://www.ptselectronicsinc.com/txn-a1ltuus/
    Maybe drop PTS a line , they've probably seen it before and I doubt you'll find an A-board for less than $95 but I'd be as descriptive of the issue as you can especially if it's intermittant.
    • Ncdude
      • Nov 2016
      • 6
      • usa
      Thank you for the reply, I was leaning towards the A board myself and you are correct in saying intermittent. I definitely don't have any lines on the screen, it just stays black or gray until it recovers. I felt it was a loose connection or broken solder but seeing those are rather tough. I will start the hunt for an A board. If you think of anything else I will be happy to listen.
      • cloo
        Panasonic ZT60 plasma tv with strange behavior and 8 blink code
        by cloo
        I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
        It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
        So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
        After doing a factory reset this problem was gone and the picture was back to...
        01-06-2025, 06:02 AM
      • Andre Gilbert
        by Andre Gilbert
        Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
        Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
        11-20-2024, 08:52 PM
      • AquaMan Ua
        by AquaMan Ua
        05-17-2025, 09:40 AM
      • stecos
        Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
        by stecos
        Hi everyone!
        For my passion for technology I'm now collecting several...
        11-28-2022, 11:39 AM
      • aa10aa10
        Panasonic Toughbook CF-33 mk1 BIOS repair
        by aa10aa10
        Good day,
        I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
        I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
        01-21-2025, 06:13 AM
