LG part
    LG part
    Well heck! LG says I have to buy a whole power supply, around 140.00
    Come on. They probably buy the part I need from Sanyo. The tv is a LG model # 55LW5300-UC service code 55LW5300-UC AUSYLUR serial # 109RMJF86708
    power supply is TB60A621699010506 1.5
    The number on the part is 11S-LS01 B another number under it FL 110221 F
    My pictures aren't very good. but here they are.
    Taft
    Re: LG part
    The part number for the board at least is most likely
    EAY62169901, EAX62876201/8, EAX62876201/9, LGP55-11SPB, CRB31006801
    Not sure how Sanyo fits into this equation but how did you determine the transformer was at fault.
      Re: LG part
      Don't know how fast or reliable they are but:
      https://www.aliexpress.com/item/POWE...6-593108145bad
      You can also try ebay:
      http://www.ebay.com/itm/LG-55LV5500-...gAAOSwHsRYCXZ2
        Re: LG part
        Transformer fault's are less likely than other components around them on power supply boards. Inverter transformers for the CCF backlights on the other hand do fail in today's sets.
        As tw2005 has asked I'm interested in how you conclude it's faulty?
          Re: LG part
          There is input voltage, but no output voltage.
            Re: LG part
            Sanyo doesn't really/ I just said that because they do make many parts for many different mannufacturer's. LG must not make their own boards if they don't have components for them. Somewhere this part I need is made. I don't want to order a whole board it is to expensive.
              Re: LG part
              Originally posted by johns1mj View Post
              I don't want to order the whole board. I just want the part number of that transformer and where it can be purchased.
                Re: LG part
                might have to find used or http://www.ptselectronicsinc.com/eay...-power-supply/
                  Re: LG part
                  good luck. I spent a fair bit of time trying all sorts of numbers and combos, never got close.
                    Re: LG part
                    The transformer needs to be switched on and off (oscillate) for a voltage to be present on the output windings. If the drive to it is missing (even if the DC voltage is present on the primary) then there will be no output voltage at the secondary.
                    Best to check that the primary and secondary windings have continuity.
                      Re: LG part
                      I looked at the board from aliexpress, and it is they have a fantastic price on it. The part number is the same but it says its is for a 42 inch screen. Mine is a 55 inch screen. Is this the right board, it does look identical.
                        Re: LG part
                        I don't have a schematic, so I don't know where to check for that drive signal. I didn't realize the voltage would be there and the transformer not be turned on. You don't by any chance have a schematic or flow chart for this tv?
                          Re: LG part
                          Unfortunately I don't have a schematic either but looking at the board at Shopjimmy I think its connected as follows.
                          The transformer pins have numbers 1 to 10 on the upper side of the pcb.
                          Pins 6 & 7 and Pins 9 & 10 are connected together and you should be able to measure resistance between the pairs.
                          Pin 2 & 8 appear to be not connected.
                          Can you measure the resistances between
                          Pins 1 to 3,4 & 5
                          Pins 3 to 4 & 5
                          Pins 4 & 5
                          That should give an idea of the transformer internal connections.
                            Re: LG part
                            What is the P/N of the SMPS IC501 which drive the primary winding of that transformer?
                            I doubt that the transformer is bad.
                            You need to find out if the IC is getting the VCC to run or not when you find the spec sheet of the IC, there are step in trouble shooting methods that should be followed.
                              Re: LG part
                              pins 1 to 3 i 3.7 ohms
                              pins 4 to 5 is 0.7 ohms
                              pin 3 to 4 doesn't show a connection
                              pin 6 to 7 is 0.2
                              pin 9 to 10 is 0.4
                                Re: LG part
                                I don't know what this means, but on the secondary of that transformer pins 6,7,9,10 all test connected.
