LG part
  • taft1957
    • Oct 2013
    • 95
    LG part
    Well heck! LG says I have to buy a whole power supply, around 140.00
    Come on. They probably buy the part I need from Sanyo. The tv is a LG model # 55LW5300-UC service code 55LW5300-UC AUSYLUR serial # 109RMJF86708
    power supply is TB60A621699010506 1.5
    The number on the part is 11S-LS01 B another number under it FL 110221 F
    My pictures aren't very good. but here they are.
    Taft
  • tw2005
    • Oct 2011
    • 6458
    Re: LG part
    The part number for the board at least is most likely
    EAY62169901, EAX62876201/8, EAX62876201/9, LGP55-11SPB, CRB31006801
    Not sure how Sanyo fits into this equation but how did you determine the transformer was at fault.
    • johns1mj
      • May 2015
      • 242
      Re: LG part
      Don't know how fast or reliable they are but:
      https://www.aliexpress.com/item/POWE...6-593108145bad
      You can also try ebay:
      http://www.ebay.com/itm/LG-55LV5500-...gAAOSwHsRYCXZ2
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Re: LG part
        Transformer fault's are less likely than other components around them on power supply boards. Inverter transformers for the CCF backlights on the other hand do fail in today's sets.
        As tw2005 has asked I'm interested in how you conclude it's faulty?
        • taft1957
          • Oct 2013
          • 95
          Re: LG part
          There is input voltage, but no output voltage.
          • taft1957
            • Oct 2013
            • 95
            Re: LG part
            Sanyo doesn't really/ I just said that because they do make many parts for many different mannufacturer's. LG must not make their own boards if they don't have components for them. Somewhere this part I need is made. I don't want to order a whole board it is to expensive.
            • taft1957
              • Oct 2013
              • 95
              Re: LG part
              Originally posted by johns1mj
              I don't want to order the whole board. I just want the part number of that transformer and where it can be purchased.
              • tw2005
                • Oct 2011
                • 6458
                Re: LG part
                might have to find used or http://www.ptselectronicsinc.com/eay...-power-supply/
                • tw2005
                  • Oct 2011
                  • 6458
                  Re: LG part
                  good luck. I spent a fair bit of time trying all sorts of numbers and combos, never got close.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Re: LG part
                    The transformer needs to be switched on and off (oscillate) for a voltage to be present on the output windings. If the drive to it is missing (even if the DC voltage is present on the primary) then there will be no output voltage at the secondary.
                    Best to check that the primary and secondary windings have continuity.
                    • taft1957
                      • Oct 2013
                      • 95
                      Re: LG part
                      I looked at the board from aliexpress, and it is they have a fantastic price on it. The part number is the same but it says its is for a 42 inch screen. Mine is a 55 inch screen. Is this the right board, it does look identical.
                      • taft1957
                        • Oct 2013
                        • 95
                        Re: LG part
                        I don't have a schematic, so I don't know where to check for that drive signal. I didn't realize the voltage would be there and the transformer not be turned on. You don't by any chance have a schematic or flow chart for this tv?
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          Re: LG part
                          Unfortunately I don't have a schematic either but looking at the board at Shopjimmy I think its connected as follows.
                          The transformer pins have numbers 1 to 10 on the upper side of the pcb.
                          Pins 6 & 7 and Pins 9 & 10 are connected together and you should be able to measure resistance between the pairs.
                          Pin 2 & 8 appear to be not connected.
                          Can you measure the resistances between
                          Pins 1 to 3,4 & 5
                          Pins 3 to 4 & 5
                          Pins 4 & 5
                          That should give an idea of the transformer internal connections.
                            Re: LG part
                            What is the P/N of the SMPS IC501 which drive the primary winding of that transformer?
                            I doubt that the transformer is bad.
                            You need to find out if the IC is getting the VCC to run or not when you find the spec sheet of the IC, there are step in trouble shooting methods that should be followed.
                            • taft1957
                              • Oct 2013
                              • 95
                              Re: LG part
                              pins 1 to 3 i 3.7 ohms
                              pins 4 to 5 is 0.7 ohms
                              pin 3 to 4 doesn't show a connection
                              pin 6 to 7 is 0.2
                              pin 9 to 10 is 0.4
                              • taft1957
                                • Oct 2013
                                • 95
                                Re: LG part
                                I don't know what this means, but on the secondary of that transformer pins 6,7,9,10 all test connected.
                                • edugimeno
                                  Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                                  by edugimeno
                                  Hi There!
                                  I'm trying to help my friend who owns a restaurant be just bought.
                                  He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                                  It's stuck using, I guess, the 2 sided tape that comes with the strip
                                  The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                                  09-05-2024, 09:34 AM
                                • G-Sting
                                  iPad Pro A1876 SHORT Part Identify Help Needed
                                  by G-Sting
                                  So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                                  So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                                  i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                                  SO My main concern is what part should i order what should i search the name for ?
                                  on Ipad...
                                  05-15-2025, 09:30 AM
                                • Yanleb
                                  Panasonic part number in service manuals
                                  by Yanleb
                                  In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
                                  This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
                                  For an example, look at the attached PDF.
                                  Do you have a way to cross reference the Panasonic part number with the actual part number?
                                  Thanks....
                                  07-03-2023, 08:16 PM
                                • FreakyMex
                                  Trouble to identify part (Lunii screen) for replacement
                                  by FreakyMex
                                  Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
                                  I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
                                  02-17-2025, 01:16 AM
                                • esinior
                                  Smd code to part number
                                  by esinior
                                  Hi i have a smd part with probably mark "QO 11" or "Q0(zero) 11" on it, and its package is SOT89, i doubt its KTB1260 PNP transistor, but in measuring with diode mode of multimeter it shows number 1.4 between emitter and collector pins and its not open circuit, and .59 from collector to base and .8 from emitter to base , and these numbers doesn't match a pnp transistor, i couldn't find any part number and datasheet for it, does anybody have information for that part number?
                                  I've attached pics of this part
                                  Thanks...
                                  08-20-2024, 02:50 AM
