Insignia NS-L22Q-10A Dim back light
  • gica69
    • Oct 2015
    • 36
    Re: Insignia NS-L22Q-10A Dim back light
    Good news is I opened and fixed the ccfl put it back together then I heard the hissing noise and now no red light for power. Don't get the 5v or 12v. No power passed the thick line that goes to IC903 to C931.
    Also IC903 only has 75v on the 2 legs toward the hot side. The other side is dead.
    • gica69
      • Oct 2015
      • 36
      OK the red light is back but no picture even with flash light, period. Weird at least the power board is sending power. I will have to test out some of the components that might have burned.
        When you make the measurement in the Hot side, what did you use for the GND ref. for the meter?
        "Good news is I opened and fixed the ccfl " What did you fix on the CCFL?
        • gica69
          • Oct 2015
          • 36
          CCFL wiring wasn't lighting up on one side, this is a 4(2+2) wire one CCFL bulb so when you plug it in on one side lights up that side, so I opened it and either the wire was somewhat disabled and while repositioning it and started to light up. So the repair was most likely just repositioning. Remember I I used an external inverter to test these wires.
          Anyways as far as ground I used the little nuts that are on the back of the monitor and hold the boards into place.
            That sounds to like typical failure of the soldering of the wires to the lamp wire ends. The wire should be properly soldered back on to the lamps ends, this is one of the common failure in the CCFL assembly.
            When you make the measurement in the primary side of the circuit, you have to use the negative leg of the main filter cap as the Gnd ref. for the meter, the reading you got is not valid due to wrong Gnd point for meter.
            • vinceroger69
              • Mar 2012
              • 6714
              #26
              i totally agree with budm regarding the broken wire on the end of the ccfl
              budm too test the ccfl he was using a external invertor i posted a picture of his invertor transformer any idea of the winding layout primary/secondary etc he needs to test to prove his onboard invertor is ok.
              • gica69
                • Oct 2015
                • 36
                Can you point out where this filter cap(capacitor?) is located? Also I no longer get the "Please Wait" screen so no lights for 2 seconds. But I get the 12V and 5V again. I get no power to the jumpers toward the 4 CCFL connectors. But I get 13V at the 5 legs of the transformer between them.
                Here's a picture of the ground I use clearly marked as GND
                Also some of the caps measure something on the top there are 2 the measure 0 ore .1V could that mean something?
                • vinceroger69
                  • Mar 2012
                  • 6714
                  #28
                  post 3 first picture large filter capacitor is laid on its side too the right of the mains plug socket one side of that capacitor has a negative line/mark so put black probe on the capacitor leg but only use this for measuring the primary side voltages (danger of high voltage so be really carefull) on the secondary side yes use a screw or the metal tv chassis as a ground to test the dc voltages. Have you used your invertor tester to make sure the lamps still light?
                  • gica69
                    • Oct 2015
                    • 36
                    OK I am back to the beginning of the thread my picture came back it's still dim but I can see the menu and have sound. So that is great. I have to fix the inverter side of it.
                    So I still need to fix the backlight issue.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      #30
                      do the backlights all work using your tester?
                      • gica69
                        • Oct 2015
                        • 36
                        Yes sir they do
                        Did you see the pictures above with the caps, some getting voltage on top some not? Also all the jumpers around the number 9(red marker) have 0 voltage.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          #32
                          so all of 4 of them light up thats good now we need to see why the invertor transformer on your psu is not powering them ive no idea what windings you need to check for shorts/open circuits etc maybe if budm/or more experienced member than me is online later he/they can look at the picture and advise us on which pin combinations to check.
                          • gica69
                            • Oct 2015
                            • 36
                            Weird how some of the caps have really high voltage on top, in the hundreds and the others are below 1V. Something wrong in the circuit. The 2 seconds of light from before is not there anymore, but the "Please Wait" screen is there just dim.
                            So just waiting for instructions from the pros.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              #34
                              retest all the voltages on the connector that goes to the main board.
                              • gica69
                                • Oct 2015
                                • 36
                                Thanks the problem is the CCFL light that was giving me problems went out completely on both sides, so with that in mind I don't think it's worth the trouble to go any further since I doubt I can find the actual light. The main board is fine, the LCD is fine even the power supply and inverter might be fine I think the problem was in the CCFL since it trigger a shut down if it doesn't work. This was a hobby project from the beginning. Thanks a lot for all the help.
                                  LCD LED TV Service Menu Codes
                                  ALL LCD LED TV SERVICE MENU CODES
                                  Service Menu Code with Board Name
                                  China Universal Board / Jumper Board Service Menu Code
                                  Changhong Ruba Service Menu Code
                                  Ecostar LED TV Service Menu Code
                                  Orient LED TV Service Menu Code
                                  Haier LED TV Service Menu Code
                                  TCL LED TV Service Menu Code
                                  Samsung LED TV Service Menu Code
                                  LG LED TV Service Menu Code
                                  Videocon LED TV Service Menu Code
                                  Supra LED TV Service Menu Code
                                  Toshiba LED TV Service Menu Code
                                  Symphony LED TV Service Menu Code
                                  Veste/ LED TV Service Menu Code...
                                  10-31-2024, 03:58 AM
                                  Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                  by sam_sam_sam
                                  This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                  I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                  I am comparing them to a brand new one that I installed
                                  The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                  I going to let it run for several days before I remount back on the wall next to the...
                                  09-05-2024, 06:48 PM
                                • PNI E.
                                  tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                                  by PNI E.
                                  hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                                  02-20-2025, 08:36 AM
                                • cajoeg
                                  Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                  by cajoeg
                                  Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                  The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                  02-10-2025, 04:01 PM
                                • koby058
                                  vostro comes up with back light but no picture
                                  by koby058
                                  Hi people!!
                                  The owner said it showed bad picture once in a while (attached)
                                  I see that there is back light but no picture.
                                  I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                                  Also attached schematic and BDV
                                  LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                                  07-13-2025, 01:03 PM
