Individual led source for backlight repair - anybody have samsung strips?
  • whitejohnny71
    • Mar 2010
    • 26
    Hi folks!
    Just found a samsung lcd tv with no backlight, power supply tests ok, backlight can be forced on by shorting past part of the string, so I disassembled the panel and found that I had 3 bad leds between the two strips.
    Does anybody have a source for generic lcd tv backlight leds?
    Or a strip pulled from a samsung with a few working ones?
    Thanks for reading, and thanks to all for making this such a great site and forum!
    john
    Re: Individual led source for backlight repair - anybody have samsung strips?
    https://www.badcaps.net/forum/showpo...&postcount=278
    https://www.badcaps.net/forum/showthread.php?t=51251
    • whitejohnny71
      • Mar 2010
      • 26
      Than you Bud! I searched a few times from google and on the site, but i guess I didn't drill down the results hard enough..
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Perhaps if you posted pictures of your led strip and the information printed on the strip could help to identify replacements.
        • vinceroger69
          • Mar 2012
          • 6714
          also what country are you in? as we maybe able to recommend various sources.
          • whitejohnny71
            • Mar 2010
            • 26
            Hi folks, it was a un32eh4003 samsung tv. Turned out I have a few samsung strips in my recycler pile, so I swapped the LEDs out (iron & hot air rework tool) and its been running for a couple hours now.
            I've attached a pic of the strips. It turned out three 9volts in series will light the whole 9 LED strip.
            To determine the bad LEDs I first connected a 9volt battery to my meter's probes and then started with the black probe on the strip's minus terminal. Then I used the red probe's tip to scratch off a little of the coating over the copper traces on the pcb strip. It took a minute to work out test points around each LED. I found 3 dead ones.
            To harvest the replacements I heated the stick around the lens and slid a 'spudger' underneath - the lens popped right off. Then I heated the back of the strip behind the led with a broad chisel tip iron and hot air and within 20 seconds I was able to slide the led off the donor strip. Then I verified anode/cathode orientation and soldered them on.
            Then, it didn't work - so I found the bad solder joint and corrected it LOL
            Tested and reassembled for burn-in, still running
            Thanks again guys!
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Looks like a good outcome. Just to give the standard warning to turn the backlights down as low as you can so as to enhance the lifetime of the led's.
                "I've attached a pic of the strips. It turned out three 9volts in series will light the whole 9 LED strip.
                To determine the bad LEDs I first connected a 9volt battery to my meter's probes and then started with the black probe on the strip's minus terminal. Then I used the red probe's tip to scratch off a little of the coating over the copper traces on the pcb strip. It took a minute to work out test points around each LED. I found 3 dead ones."
                Be real careful when testing any LED without current limiting, for example, if the 9-LED strip has one or more shorted LED so when you apply 27VDC to the strip, the good LEDs can be damaged due to over current because of the shorted out LED/s.
                • 102mm
                  • Dec 2013
                  • 181
                  • us
                  How do you limit the current when testing the strip?
                  Craigslist Picks & Fixes
                  2 ea - Samsung 52"
                  Samsung 60"
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Best way is to use a power supply which has current limit or use the led strip testers that are now on the market.
                      09-07-2024, 05:50 AM
                    • C152Heavy
                      by C152Heavy
                      Summary for TL-DR readers:
                      • VCC pin (18) of PFC...
                      01-11-2023, 02:53 PM
                    • sansanpartida
                      Samsung QE82Q70RAT no backlight
                      by sansanpartida
                      Hi everyone!
                      Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                      My issue: No backlight.
                      Model: QE82Q70RAT
                      Type No: QE82Q70RAT
                      The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                      So hopefully, I can fix this cheaper.
                      05-22-2024, 06:56 AM
                    • Kingfreddie
                      LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
                      by Kingfreddie
                      Ok.. this is the story:
                      Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
                      This is kinda how it looked, just that mine were at the bottom of the screen:
                      09-11-2021, 01:57 AM
                    • howardc64
                      Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                      by howardc64
                      TV was fixed just after removing Samsung's rear snap cover.
                      This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                      Maybe PSU->backlight connector didn't have a good contact?...
                      07-23-2025, 12:34 AM
