Anybody can HELP ? LG50pj350 sound but no picture !
  • vasce
    • Sep 2016
    • 21
    Hi all. Have this LG50pj350 which screen has been replaced. I can hear the sound, switch channels but there is no picture. The screen is intact.
    Anybody may have a clue ?
    Thanks to anybody who will give an answer.
  • tw2005
    • Oct 2011
    • 6458
    Re: Anybody can HELP ? LG50pj350 sound but no picture !
    At a guess I'd be thinking sustain board failure or maybe buffer failure. I might have a training guide.
    Tried searching the model and look for similar fault description?
    I only touch the Panasonic stuff but sound no picture is a fairly common fault description for the LG and Samsung stuff.
    I would also try turning the TV on in a dark room and see if you can notice the panel fire up at all. If it does it may be main board and there should be a test pattern feature in that guide to isolate the main board.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Advise do some research on google plus the forum. Read what you should add to a thread. Run the test patterns. Test voltages. Help us help you.
      • vasce
        • Sep 2016
        • 21
        Thank you mates for your answer. As I'm not an expert and don't have tools to test voltages, I'll follow your advises anyway and see if I can provide better information.
        Have a good day.
          BTW, who did the screen replacement? Used one, new one? Properly installed?
          • vasce
            • Sep 2016
            • 21
            Hi BUDM. I bought the screen from a technician and replaced it by myself. I simply reinstalled like the previous one was. The replacement was a used one but has no cracks. I will check all the connections anyway.
            Cheers
            • vasce
              • Sep 2016
              • 21
              Hi again.
              Here's some pics attached
              Don't know if someone can see anything that's wrong ?
              Thanks.
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
              • Ierwin
                by Ierwin
                05-13-2025, 03:31 PM
              • jchang
                Samsung UN70NU6900F no picture and no sound
                by jchang
                Hi all
                I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                Symptom:
                No picture no sound.
                When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                No sound at all.
                What I tried:
                1. I tried unplugging the left or right ribbon...
                01-09-2023, 06:28 PM
              • ChaosLegionnaire
                by ChaosLegionnaire
                09-13-2022, 09:02 AM
