Westinghouse LD-4055
  • Jason616
    • Sep 2016
    • 99
    Tv powers up but screen is flickering and there is a horizontal line at the bottom of the screen ..
    I will be home in a lil bit of pics are needed ..
    Anyone know what might cause this or where to start checking ?
  • Ado02
    Lenovo Thinkpad X1 Gen 10 - Flickering Screen
    by Ado02
    We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the IntelĀ® IrisĀ® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
    The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
    12-16-2024, 02:33 PM
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • survivalbloke
    HP ENVY HP 13-aq1013dx - screen flickering black if using touchpad or external mouse
    by survivalbloke
    SN: 8CG0213H8W
    ProdID 3C311UA
    This device came in due to the screen flickering if you use the touchpad or external mouse. It will flicker black when this occurs. If you use the touchscreen, the behavior does not appear. Also, if connected to external monitor, the external monitor is not affected by the flickering. I did a good amount of research on this, and concluded that it is due to the display driver. HP does not offer Windows 11 drivers for this model so I got the replacement drivers direct from Intel. I installed them and the problem...
    05-08-2025, 12:21 PM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
