Panasonic SC Board TNPA5728 Help
  • BigPete
    • Jul 2012
    • 76
    • New Zealand
    I have a set with 7 blink problem.
    I have removed buffers and shorted SC50 and TV is still on 7 blinks.
    I checked the voltages and the only one that is suspect is the VAD one.
    The other voltage power up and hold briefly, the VAD doesn't.
    I have checked for shorts and can't find any.
    SM is here:
    Which ICs should I be checking?
    Pic is here http://www.ebay.com/itm/Panasonic-TX...wAAOSwa-dWmEmz
    Cheers
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
    After all of...
    07-13-2024, 08:14 PM
  • canadaboy25
    Panasonic TC-P54VT25 No image. A or D board?
    by canadaboy25
    I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
    I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
    01-17-2021, 01:06 AM
  • dajoker
    Panasonic th-p50s10d - blinky red, SC board go boom
    by dajoker
    My old plasma died when one night recently. When I got to it it was giving a 3.3v sos (3 blinks).
    I chased my way through the PSU, and a board, with no results.
    Replacing a few bulged caps in the PSU, I eventually got to the SC board that had piles of shorts, a quick cheap replacement from china and the tv powers up again, except
    I only have the right half of the picture.
    Left half is completely blank.
    now the c3 board running this side of the screen has its 3.3 and 5v onto the buffer ic and its got the 60v, so that all seems good.
    all the other voltage rails...
    09-24-2024, 04:39 AM
  • Rictech
    Panasonic SA-MAX770PU SMPSU board fault....
    by Rictech
    Hello everyone. 😀
    As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
    Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
    Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
    This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
    There are no devices that have exploded or otherwise show signs...
    08-26-2024, 01:05 AM
