Vestel 17mb25 + 17pw26-4
  • nashagui
    • Jan 2015
    • 19
    • Spain
    Bad image, good OSD.
    I change EEPROM 24C32 and problem continues.
    I tried with a external TDT, internal TDT and HDMI.
    I look into service menu and check an error on HD.
    I think that there are some circuit with a short circuit.
    Re: Vestel 17mb25 + 17pw26-4
    Looks like bad GAMMA Voltages on the T-CON board, it can be due to bad GAMMA Vref IC or wrong panel setting in the service menu.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Go into SM-4725 then find Lvds mode normally in the picture section and change its value. Problem solved. Also consider checking Tcon voltages could be gamma Ic as bud says.
      • nashagui
        • Jan 2015
        • 19
        • Spain
        I enter in service menu but i cant change lvds mode.
        I think that problem is some lm1117 regulators.
        • nashagui
          • Jan 2015
          • 19
          • Spain
          now, I change LM1117 regulators but problem continues,... I this that there are a short circuit in anywhere
          • lilas3305
            • Oct 2014
            • algerie
            helo , are there as15g in t-con? change it
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              What is the model number of your TV and can you supply sharp pictures of your boards.
              • nashagui
                • Jan 2015
                • 19
                • Spain
                Lilas3305, no as15... This is the first think i search
                • nashagui
                  • Jan 2015
                  • 19
                  • Spain
                  Dick_barton model number is Oki V26A-H and attach pictures of boards asap.
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    Is this your Tcon board
                    http://www.ebay.ca/itm/T-CON-LVDS-BO...gAAOSw5ZBWH92T
                    • nashagui
                      • Jan 2015
                      • 19
                      • Spain
                      No tcon board.
                      Tcon is integrated con main board ... Vestel 17mb25
                      Cable conects main board directly panel
                      • Astonished
                        Fixing the Charge Circuit of the Batteries of the DC Motor
                        by Astonished
                        Hi friends of electronics
                        What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                        The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                        Please help me fix this circuit.
                        (the datasheet of the IC: https://pdf.datasheet.live/28...
                        01-28-2025, 06:24 AM
                      • Tarot Superstars
                        Short Circuit tester
                        by Tarot Superstars
                        Hello.
                        I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                        The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                        Link
                        The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                        https://www.youtube.com/watch?v=0eixDdCpiO4
                        My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                        09-25-2023, 09:11 AM
                      • France_53
                        Vestel tv, how to flip the image?
                        by France_53
                        Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                        05-12-2024, 05:22 AM
                      • M1NEBLANK SHOW
                        MSI B250 Gaming M3 Short circuit in CPU power supply circuit
                        by M1NEBLANK SHOW
                        Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
                        (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
                        Schematic and Boardview here
                        04-04-2025, 03:57 PM
                      • прямо
                        Viper22A 5VSB circuit
                        by прямо
                        So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                        In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                        01-13-2024, 07:05 PM
