What does THIS failure look like to you guys ? (a Myria LCD TV)
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Greetings fellow cappers, quick and simple one today: got this Myria....thing....junk-dive LCD which has some color problems and was wondering what you guys think the fault is: panel or T-CON board. The pictures don't do it justice too well, since cameras don't "see" screens the same way our eyes do, so I'll try my best to describe it: basically the colors are a bit messed up It's most visible in the picture with the home screen of an android box I use for testing: notice how the background has a highly uneven color when it should look like THIS. The whole thing seems to have a tint of purple to it and there's also "ghosting" going on (when an image changes suddenly, such as a menu going away, it leaves behind a grayish-purple afterimage that takes quite a while to disappear). Forgot to mention it affects all inputs. Don't know how else to describe it but it all boils down to two issues: bad T-con or bad panel. Now while I was taking those pictures, it had been running for like 5-10 minutes and at one point the colors suddenly improved slightly ! They weren't brilliant, but definitely better, especially on those SMPTE test patterns.
    I got to the T-con which was buried underneath tons of metal and identified the gamma chip which I read is usually the cause of such "solarized' picture. I know you can't see it, but it's an AS15F chip. A fellow of mine tried blasting it with some flux and hot air but nothing changed, but that could very well be because he did a sloppy job - I feel like he didn't heat it long enough. I will try taking over with actual solder and a soldering iron, but before I do that, what does this look to you : is it worth the struggle, or is the chip busted (or perhaps the panel ?) :| I'll start measuring those test pads as suggested in another thread around here if need be, but for now just let me know if I'm on the right track. It's such a bullshit designed TV that I can't really access the T-CON with the TV fully assembled, since it's placed under a metal chassis that holds the power supply and logic boards, so it's not gonna be easy to run it and measure it at the same time Cheers.
    Wattevah...
  • diif
    • Feb 2014
    • 6978
    • England
    Re: What does THIS failure look like to you guys ? (a Myria LCD TV)
    Reflowing the AS15F chip doesn't tend to work. They are so cheap if it's a gamma issue I just replace the chip. It's quicker than measuring.
    • finntricky
      • Jan 2014
      • 449
      defo replace AS15, chip, problem solved
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        • Romania
        Yup - nailed it. Replaced the gamma IC and it now works perfectly. Cheers
        Wattevah...
        • CapLeaker
          Leaking Member
          • 8208
          if you would have measured the gamma voltages on the AS-15, it also would have been a dead give away.
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            Apparently the AS15F failed again (at least that's what the guy told me over the phone - let's hope he's crazy and he's seeing funny colours )...could it be because of heat or improper supply voltage ? The power supply of this TV makes a HORRIFIC squealing noise that seems to be coming from the PFC inductor. Probably unrelated, but it's a thought...
            Wattevah...
            • steviewonder
              • Dec 2013
              • 183
              • england
              there's probably a clapped out capacitor on the psu-causing spikes to reach the AS15.,which is most likely the cause of the squealing noise...Look for the lower value ones,100uf and below,and replace those in the drive circuit.
              Not familiar with your set,but that type of psu noise is quite common when the caps dry up!
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                I suppose I should inspect the caps on the 12V line, since I believe that's what the t-con operates at. I remember some of them getting VERY hot indeed.
                Wattevah...
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  I've noticed some of the metal shields that cover the T-con have thermal pads over the AS15 and some don't. I've missed the thermal pad off before and seen the AS15 die in a very short time.
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    Originally posted by diif
                    I've noticed some of the metal shields that cover the T-con have thermal pads over the AS15 and some don't. I've missed of the thermal pad off before and seen the AS15 die in a very short time.
                    This one didn't have a heatsink, nor did it show any signs of someone removing it before me, as it would've had SOME sort of visual clue - a mark, a smudge...something. I actually thought of adding one myself, but I scrapped the idea thinking it wouldn't be an issue, that's why I asked about the possibility of this second failure being caused by heat.
                    Wattevah...
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      • Romania
                      Oh yeah, the symptom is different this time: the picture is white and badly washed out....I'm sure it's caused by the same IC, but I'll try reflowing it first, since I believe that my workmate did a sloppy job and it fell apart when the IC got hot....just a theory though...
                      Wattevah...
                      • CapLeaker
                        Leaking Member
                        • 8208
                        I think bad AS-15 again. If it isn't heatsinked, then put one on there.
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          • Romania
                          I replaced the AS15F again, but it didn't fix the issue this time: the picture is still white and very "grainy"...what could be the issue ? Perhaps the main board or something else on the T-CON ? The T-CON is a V32B C3 by the way...I read something about a Q300 going bad, but I don't know what to replace it with...this sucks......:|
                          Wattevah...
                          • Sus256
                            HISENSE 65E7KQ PRO - no boot
                            by Sus256
                            Hi all!
                            HISENSE 65E7KQ PRO
                            RSAG7.820.13512 - chassis
                            MT9618BAATAB - cpu
                            RSAG7.820.12059 - power
                            HD650Y3U77 - panel
                            KLM8G1GETF - emmc
                            The TV does not turn on, the standby indicator is on. All voltages are present.
                            Emms is dead. Not readable, not detected.
                            Replaced emmc.
                            But with another dump there is no launch
                            Terminal log
                            UART
                            AC_ON
                            RPMB key is not yet programmed
                            HASH1_VERSION=0x00000000 64bit
                            E-B
                            FDE enabled
                            layout pattern onebin by SAR7,0...
                            06-01-2025, 02:11 AM
                          • howardc64
                            by howardc64
                            07-24-2025, 05:17 PM
                          • ctroxtell
                            Carrier HK50AA063 display controller common failure help
                            by ctroxtell
                            I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
                            02-05-2025, 05:31 PM
                          • howardc64
                            Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                            by howardc64
                            Problem
                            Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                            Model & Board Pics
                            Conflicting Spec
                            Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                            https://www.shopjimmy.com/vizio-gj-2k1...
                            10-10-2024, 01:16 PM
                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                            by sam_sam_sam
                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                            Found shorted diodes on main controller relays there are 3 of them that...
                            01-07-2023, 05:43 PM
