VIZIO E550VL No Backlight
+ More Options
Posts
  • CraigR
    • Dec 2013
    • 959
    I have a old Vizio E550VL with no backlight. I do have a picture when I use a light up to the screen. The fuses on the inverter boards are ok and I have 24volts at those fuses when turned on. Not sure on the next step.
    Re: VIZIO E550VL No Backlight
    Next step is to check and find out if you have 24VDC at both ends of the SMD fuse on the inverter boards with ref to the chassis GND or not.
    If you do, the you will need to find out if you have BL-ON signal to the inverter board or not.
    • CraigR
      • Dec 2013
      • 959
      I do have 24v. However not seeing anyplace marked bl_on or I'm blind. I did see one marked ON/OFF on inverter and that only has .5v
        ON/OFF on the inverter board is the same as BL-ON or INVR-ON.
        IF all you get is 0.50VDC when the TV is turned on then the main board is not sending the ON/OFF (BL-ON) to turn on the Backlights circuit.
        • CraigR
          • Dec 2013
          • 959
          Well ordered and tried a kit from Shopjimmy. http://www.shopjimmy.com/vizio-3655-...for-e550vl.htm
          But did not help at all.
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            But were you getting the backlight on voltage as Budm advised because as he said it is provided by the main board?
            • CraigR
              • Dec 2013
              • 959
              Still only .5v after chips change.
              • CraigR
                • Dec 2013
                • 959
                Replaced the main board and is working again.
                • SS454
                  vizio e650i-a2 backlight flashes then turns off
                  by SS454
                  vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                  panel: au optronics T650HVN05.4
                  72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                  link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                  Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                  https://www.shopjimmy.com/vizio-56-0...-power-supply/
                  Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                  08-20-2020, 03:57 PM
                  Surface Mount Fuses Fundamentals Datasheet
                  TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                  TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                  10-07-2024, 06:07 AM
                • Yanleb
                  Vizio M70-D3 4K with dark spots backlight issue
                  by Yanleb
                  I have a Vizio M70-D3 4K with a dark spots backlight issue. It is using the Y8387248A backlight driver board.
                  On this model each of the 64 transistor powers 2 LEDs. Using my TKDMR TD3H backlight tester I've determined that the backlight LED strips were the issue, and the backlight driver board was just fine. Some LED pairs required 5.9 volt at 155mA, some required 9.5 volt and some were completely open.
                  I've removed the LCD panel and once the LED strips were exposed I've tested them again by connecting my LED tester directly on the test pads. To my surprise all, I've...
                  03-22-2022, 01:06 AM
                • howardc64
                  Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                  by howardc64
                  Problem
                  Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                  Model & Board Pics
                  Conflicting Spec
                  Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                  https://www.shopjimmy.com/vizio-gj-2k1...
                  10-10-2024, 01:16 PM
