Samsung UN46D6900WF no picture
    Have a Samsung UN46D6900WF with no picture. Backlight seems to fire then powers off, you can hear a relay click on then click off when it click off the screen you can't see the blacklight from front but can see thru small holes in the back when cover is off the panel is lit slightly. If I disconnect the power cable from power supply to main board the backlight will remain on. I have replaced the main board with the same result. Power supply? Any help would be great. Thanks Steve
    Re: Samsung UN46D6900WF no picture
    bump
      Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
        "If I disconnect the power cable from power supply to main board the backlight will remain on."
        It means the power supply and backlights circuit are fine.
        We NEED good clear pictures, the P/N of the power supply board BN44-?????.
        You also need to check the DCV on the power supply board connector that goes to the main board (connector put back in place) so we can see what signals are missing from the main board.
        BTW, the replacement boards are guaranteed to be good working boards? The P/N on the barcode stickers matched the original bard?
          Thank you for your replies, see attached pics. Board mounted to back of TV is now the replacement looks to be the same model and even produced in the same month/year.
            OK, the power supply board is BN44-00427B.
            You need to check the DCV on the connector CNM802, there is a pin listing by the jumper JP902.
            You need to provide the pin name and follow by the DCV reading when the power switch is activated so we can see what is/are missing.
            Pictures provided by shopjimmy.
              here is what I have, Attached is my pin out and they match the picture from shopjimmy.
              PIN:
              1 - 6.5V
              7 - 33.67V
              9 - 38V
              10 - 162V
              17 - 24V
              18 - 15V
              19 - 24V
              20 - 16.2V
              If you need anything else let me know.
              Thank you!
                PIN:
                1 - 6.5V
                7 - 33.67V
                9 - 38V
                10 - 162V
                17 - 24V
                18 - 15V
                19 - 24V
                20 - 16.2C
                Thank you!
                Well,
                1) there are 20 PINS on the connector.
                2) Where are the pin names as requested.
                3) What did you use for the GND ref. for your meter?
                4) No way you can have 38V, 162V on the pins, the power supply board and the main board would have blown up big time as you can what the Voltage labels for those pins are. The meter is good?
                5) Do you have the connector back in place as suggested when you made the measurement?
                  I checked my meter had low battery.
                  Here are the new #'s
                  1 - OD_LE - 3.294
                  2 - PWM4 - .320
                  3 - OD_ON - 2.376
                  4 - PWM3 - .320
                  5 - GND - 0
                  6 - PWM2 - .320
                  7 - B13V - 12.83
                  8 - PWM1 - .32
                  9 - B13V - 12.83
                  10 - B13V - 12.82
                  11 - Vamp - 12.83
                  12 - BLU - 4.88
                  13 - Vamp - 12.82
                  14 - GND - 0
                  15 - GND - 0
                  16 - GND - 0
                  17 - B5V - 5
                  18 - A5V - 5.29
                  19 - B5V - 5
                  20 - PS - 3.33
                  Using Pin 5 as ground and connector is connected.
                    1 - OD_LE - 3.294
                    2 - PWM4 - .320
                    3 - OD_ON - 2.376
                    4 - PWM3 - .320
                    5 - GND - 0
                    6 - PWM2 - .320
                    7 - B13V - 12.83
                    8 - PWM1 - .32
                    9 - B13V - 12.83
                    10 - B13V - 12.82
                    11 - Vamp - 12.83
                    12 - BLU - 4.88
                    13 - Vamp - 12.82
                    14 - GND - 0
                    15 - GND - 0
                    16 - GND - 0
                    17 - B5V - 5
                    18 - A5V - 5.29
                    19 - B5V - 5
                    20 - PS - 3.33
                    OK, there is no missing control signals and the Voltages are fine, since you can see the screen glow but no pictures, then the next place to test will be the 12VDC on both end of the SMD fuse on the T-CON board with ref. to GND.
                      both sides read 12.67V
                        Try having one ribbon cable between the T-CON and the LCD panel connected one at a time and see you will get image on the screen.
                        Pictures of the T-CON board?
                          With the left side disconnected same backlight lights for a second. right side disconnected Samsung logo displays then go away.
                            Do you mean you can actually see SAMSUNG logo display on the screen when the right side is disconnected but if both ribbons are connected you do not see the SAMSUNG logo on the screen at all, right?
                              In picture 1 of previous post half samsung logo is display on side that has ribbon cable connected other half is blank. Picture two lines displayed. see attached pics.
                                OK, since you are able to see the image on half the screen with only one cable connected to the LCD panel, to me that indicates bad panel. You can try new T-CON if you want.
                                  Thank you for your help! Any harm in swapping the ribbon cable position on T-Con board?
                                    Not at all, they are the same size, pin count, and style.
                                      Results:
                                      1st photo shows the connection and second shows results.
                                      When I connect the right side T-Con(looking from the back not screen side.) to the left lcd connector the right side(looking from back) lcd displays solid white no logo.
                                      3rd shows the connections and fourth shows results.
                                      When I connect the left side T-Con(looking from the back not screen side.) to the right lcd connector the left side(looking from back) lcd displays solid white no logo.
                                        "Thank you for your help! Any harm in swapping the ribbon cable position on T-Con board?"
                                        OK, I misread your question, you are talking about the position not the two ribbon cables which the cables are the same, I thought you are trying to swap the two cables to find out if you have bad cable.
                                        I never try swapping the POSITION because I do not know what the signal difference between the two connectors are.
