LG Plasma 50PS11, No picture but still has sound
  • TArmstrong
    • Sep 2016
    • 4
    Just looking for some diagnostic advice for my 50" LG plasma, since i'm too cheap to buy a new TV.
    TV has a lot of hours on it, recently the picture stopped working but the sound still works. I have browsed these forums and some youtube channels and started some diagnostics.
    So far I have tried running the board with the Y-Sustain disconnected, upper Y drive disconnected, lower Y drive disconnected and the z sustain board disconnected.
    There was no picture in any of these cases and I have power on both sides of the fuse on the Y-Sustain and Z-sustain boards.
    Any suggestions on what I should check or measure next to isolate the problem?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG Plasma 50PS11, No picture but still has sound
    Help us help you, upload images and voltages that you have tested first !
    • TArmstrong
      • Sep 2016
      • 4
      See attached pics.
      1st pic is Ysus VS+
      2nd pic is Ysus VA+
      3rd pic is a closeup of Y sus power input?
      4th pic is Ysus +5V
      5th pic is Zsus VS
      6th pic is Zsus +5V
      Any ideas what I should check to help isolate the issue?
      Thanks for the help.
      • TArmstrong
        • Sep 2016
        • 4
        I measured VZB (tough to tell where to measure) on the zsus board at 112 V. This doesn't match any voltages on the pan sticker.
        Would this point to a bad zsus board?
        • Jeff Pepin
          • Jun 2014
          • 103
          • CANADA
          I have fixed 2 of these at this time this week but one give me headhashes now im about to post a thead about it
          If you are lucky this resistor transformed himself into a powerfull toaster and opened (check attached pictures ) it look like a very common failure i got it on 2 of 3 y sustain . To prevent that this one blow again i replaced it by a 5watts ceramic resistor , the value is 2.2 ohms
          • Jeff Pepin
            • Jun 2014
            • 103
            • CANADA
            The second one that give me headhashes the resisstor was fine , but i have found 2 fets labeled "45F122" dead but not shorted located on the center heatsink of the y sustain
            Is a lot of work but you need to remove entire heatsink with fets on it , after that you can test each one by put your dmm in diode mode and placing your red probe on left pin , black probe on center pin to charge the gate, then immediately put the red probe on the center pin and the black on the right pin you should have a reading that prove that it switched on
            Then , leave the red probe on center pin and go toutch the left pin with your black probe to switch it off , now put again your black probe on the right pin and you should read O.L , replace it if it show no signs of life
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Ive also had a very little fet that drives the transformer in the lower right hand corner covered in glue fail shorting the 5v rail on Ysus.
              • KYBOSH
                Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                by KYBOSH
                Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                No picture but you hear the TV static (white noise) playing loud and clear.
                The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                But it seems they didn't get too far and just left it.
                When I first took a look I was amazed at how pristine the inside looked.
                Its as if the TV had been in a time capsule.
                Caps looked like they were just pulled off the self.
                Copper coils had no sign of corrosion on...
                02-01-2023, 11:10 PM
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
              • Ierwin
                by Ierwin
                05-13-2025, 03:31 PM
              • jchang
                Samsung UN70NU6900F no picture and no sound
                by jchang
                Hi all
                I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                Symptom:
                No picture no sound.
                When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                No sound at all.
                What I tried:
                1. I tried unplugging the left or right ribbon...
                01-09-2023, 06:28 PM
