UN60F7050AF issue (5x) double blink
  • justice171
    Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
    by justice171
    I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
    Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
    1. Verified that all critical voltages are present:
      • 3.3V and 5V are always present if DC is plugged.
      • 1.8V on the BIOS chip is present.
    2. Checked the power button functionality:
      • When pressed, the voltage drops to 0V, indicating the button is functional.
    3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
      • Confirmed connectivity is intact, ruling out issues
    11-26-2024, 12:39 AM
  • david sen
    Samsung QE75Q60A - bootloop, double blink, no display
    by david sen
    Got this 75" TV for free, spent 10+ hours looking into solutions and troubleshooting methods before posting, I would hate for this device to become e-waste.
    The issue:
    backlight turns on, goes dim, turns off and the red light blinks twice.
    unlike the numerous videos I have seen online I can hear an audible click from the relay switch on the p9wer supply board.
    What I tried:
    disconnecting the main board from the power supply = backlight turns on and stays on.
    disconnecting the ribbon cable from the mainboard = backlight turns on, there is...
    09-24-2024, 07:29 AM
  • tbsmith
    Ninja DCT401 Double oven/air fryer Possible microprocessor issue?
    by tbsmith
    I'm having a random issue with this otherwise nice double oven/air fryer. It sometimes does not respond to the controls. Sometimes only the upper control buttons work, sometimes they all work and sometimes none of them work. The power supply is good as the control board has a steady 5V and 3.3V. The pushbutton switches are all good as tested with multimeter. When the buttons are working, there is about 2.5V to the high side of the pushbutton. I'm assuming pressing a button grounds the input pin to the microprocessor. When the buttons are not working, there is about 0.3 volts on the high side....
    07-12-2025, 11:40 AM
  • alltvrepairs
    Samsung HG49EE690 Hospitality TV reboot issue Mainboard BN94-11086A
    by alltvrepairs
    I have 3 of these TVs for repair with same problem of going to standby after around 10minutes and start again continuously. I have tried a new SPI 25Q40 but fault remains. Am suspecting a CPU problem as it gets a bit hotter than I expect.
    This seems to be a common problem in these models. I am 100% sure it is a mainboard issue as I have fitted a spare from a normal TV from a UE40K5607 and stays on (diplay inverted but I managed to rotate in SM using a different display).
    Any help appreciated!...
    03-14-2024, 03:39 AM
