Samsung QE75Q60A - bootloop, double blink, no display
  • david sen
    • Sep 2024
    • 5
    • Egypt
    Got this 75" TV for free, spent 10+ hours looking into solutions and troubleshooting methods before posting, I would hate for this device to become e-waste.
    The issue:
    backlight turns on, goes dim, turns off and the red light blinks twice.
    unlike the numerous videos I have seen online I can hear an audible click from the relay switch on the p9wer supply board.
    What I tried:
    disconnecting the main board from the power supply = backlight turns on and stays on.
    disconnecting the ribbon cable from the mainboard = backlight turns on, there is sound and the TV reacts to the remote.
    The driver board is split into 3 parts, connected by two flat cables. Unfortunately, unplugging each end still causes the power cycle.
    Since I cant isolate the issue I tried taping the main ribbon cable.
    managed to isolate and tape 4 pins (15-18 from the left), still there is no image.
    tried taping other parts of the ribbon cable, when I tape pins 1-4 from the right, the bootloop also stops but there is still no image.
    Is there any way to proceed from here?
  • Diah
    • Feb 2013
    • 6416
    did you trick out the T-CON on mainboards to by pass the protection? there are 2 points on it need to jumper first..... if you dont then post clear photo on yours MB right side TOP
    • david sen
      • Sep 2024
      • 5
      • Egypt
      No I have not, this is my first time trying to fix a TV
      taping just 1 most right pin on the ribbon cable stops the power cycle but there is no image.
      • Diah
        • Feb 2013
        • 6416
        what a funny boards no print sign on it,,,, you may have the print on the back side !!
        however from your masking to stop the boot loop its 100% panel issue, search after and tested yours panel bufferr boards the middle parts we do have another threat i think same panel... there are D MOSFET and SPIas well C
        • david sen
          • Sep 2024
          • 5
          • Egypt
          Yeah, it's definitely a panel issue.
          I still wonder If I can get any image to show up, even if it's bad.
          • lotas
            • Jan 2016
            • 4708
            • Russia
            Two blinks of the Standby LED indicate a problem in the panel, install a jumper and repeat the procedure with disconnecting the U-loops.
            • david sen
              • Sep 2024
              • 5
              • Egypt
              No change in behavior, even with the jumper, disconnecting one or both U-loops still causes power cycle
              • Takeatry
                • Jul 2024
                • 31
                I have a Samsung QN50Q with a similar main board experiencing the boot loop. I have narrow the problem to the right panel looking from the back. Tape method has worked to get a good enough picture in the past but never permanently. After letting the tv sit for any number of hours the loop would start again. Question for now is if I get a picture in do I need to remove the jumper wire on the main board or must it be removed
                • lotas
                  • Jan 2016
                  • 4708
                  • Russia
                  The jumper is placed for diagnostics.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4423
                    • Italy - Milan
                    If you were able to locate the right points on the Ma.Bo. you can probe the typical panel/tcon voltages, when jumper is on.. evidenty no voltages no image, but if yes voltages, then maybe a software trick is present, you know, today's Samsung are rubbish, you can expect everything, on the panel there is a memory chip, who knows..
                      09-07-2024, 05:50 AM
                    • howardc64
                      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                      by howardc64
                      • Prior owner tried a replacement main board. No difference.
                      • Samsung 2x red blinking standby LED = panel fault
                      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                      07-19-2025, 10:54 PM
                      09-06-2024, 11:40 PM
                      09-06-2024, 08:40 PM
