samsung UE40ES5500W from red to green to blue....
  • joe-joe
    • Aug 2016
    • 37
    • België
    this tv starts up without the samsung logo
    and just turns from red ,to green to blue to blank to black
    over en over again!!!
    sound is ok,
    t-con board?????
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: samsung UE40ES5500W from red to green to blue....
    Enter the service menu and factory reset the Tv. Tcon is not the issue as its able to write the RGB images to the Lcd screen it will be the mainboard.
    • aaronwt6
      • Apr 2013
      • 855
      • US
      Most likely you have a corrupt eeprom. Doubt you'll be able to enter the service mode or do anything else with it.
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        Can this set rewrite the eeprom data if a blank is fitted?
        • aaronwt6
          • Apr 2013
          • 855
          • US
          I'm unsure, but I've seen some UNxxES TVs in the same state. They are stuck in some type of test mode.
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            I know from reading the threads that some sets can and maybe one of the more experienced members will have an answer.
            • joe-joe
              • Aug 2016
              • 37
              • België
              i can t come in service mode!!!!????
              mute-1 8 2 -power on
              the tv starts with the same pictures!!red-green .........
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                Try Info, Menu, Mute, Power ON
                • joe-joe
                  • Aug 2016
                  • 37
                  • België
                  already tryed it!!!no differens!?
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    You are trying with the set initially in standby?
                    • aaronwt6
                      • Apr 2013
                      • 855
                      • US
                      You cannot access anything when the TV is in this state from my experience with similar ones. It's stuck in a loop of the test colors and will not respond to the remote or buttons.
                      • dick_barton
                        • Aug 2015
                        • 6642
                        • Wales
                        EEprom firmware may be available from this Russian site.
                        http://**************/pda/board/lcd_.../241-1-0-24043
                        • joe-joe
                          • Aug 2016
                          • 37
                          • België
                          i got a tip that it s the cable between the t-con and the power supply!?
                          where can i find a new one?
                          the russian site doesn t give answers!
                          • joe-joe
                            • Aug 2016
                            • 37
                            • België
                            i found a cable !but it didn t help! also on the russian site i dont find anything that can help me!
                            does anyone has more idees or tips!?
                            thanks
                            • joe-joe
                              • Aug 2016
                              • 37
                              • België
                              it is the t-con board!!!!i ordered a new one but would like to find the cause?
                              on the board itself
                              it is a sharp t-con 5246TP
                              thanks
                              • dick_barton
                                • Aug 2015
                                • 6642
                                • Wales
                                I don't believe its your Tcon if the panel is clearly looping through the test colours. It's highly likely your EEprom is corrupted as indicated by Aaronwt6 in post #3
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  yes i agree i doubt its a t con issue certainly sounds a mainboard fault too me like its in a test mode.
                                    What is the LCD panel model number? The spec. sheet of the panel may tell you which pin of the T-CON board is used for setting up the test mode then you can see if that pin is stuck in test mode or not.
                                    • joe-joe
                                      • Aug 2016
                                      • 37
                                      • België
                                      ordered and replaced a new t-con board!
                                      and yes !it s working again!
                                      thanks for your posts
                                      • dick_barton
                                        • Aug 2015
                                        • 6642
                                        • Wales
                                        Well, I live and learn. Well done.
                                          09-07-2024, 05:50 AM
                                        • String2016
                                          samsung np300e green screen
                                          by String2016
                                          I need help on this samung np300e laptop, laptop turns on but the display green screen samsung logo and no bootable device shows but all green, I have replaced good lvds cable and good screen still problem persist.anyone encounter this problem please help
                                          07-26-2025, 04:00 AM
                                        • Egidio85
                                          Samsung NP750QFG-KA3DE does not turn on , Blue LED flashes 3 times
                                          by Egidio85
                                          Hi everyone, I have a Samsung NP750QFG-KA3DE , MainBoard VESTA3-15 BA92-24515A
                                          the battery is charged. pressing the power button the blue LED flashes 3 times and then stays blue. then the sequence repeats.
                                          the fan does not start.
                                          I noticed that I have no power on the processor and it does not heat up. could it depend on the bios?​
                                          any advice on what to check?
                                          06-10-2025, 05:00 AM
                                          09-06-2024, 11:40 PM
