Panasonic tx42-p42x20E problem
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Panasonic tx42-p42x20E problem
    Will be easier, cheaper and faster to replace whole board--dont waste your time messing with the original.
    TELEFIX
    • AquaMan Ua
      by AquaMan Ua
      05-17-2025, 09:40 AM
    • hugocarmo
      Panasonic TX-24A1UN CRT Sound and Input problem.
      by hugocarmo
      Hi.
      I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
      It is imaculate inside, almost no dust or debris inside.
      The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
      So I started to look for a service manual, I found one, and started from the beginning.
      Most of the times the caps are the problem so I orderer all the caps for all boards,...
      04-26-2025, 07:45 PM
    • renech
      panasonic TH-42PC77U plasma television half screen problem
      by renech
      hello,
      I hope someone on this forum can assist me.
      I have a panasonic TH-42PC77U plasma television.
      the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
      i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
      I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
      I have read some posts that suggest the problem is related to the boards on the left...
      12-12-2022, 06:53 PM
    • Vebririon
      panasonic TX-P50V10E 6 blink led problem
      by Vebririon
      I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
      Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
      I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
      05-17-2025, 10:16 AM
    • theone111
      by theone111
      3. Problem: TV shuts down
      07-22-2024, 10:36 AM
