Panasonic tx42-p42x20E problem
    Hi
    First for to all for this forum. I have a plasma problema and i think The only solution is change mainboard.
    I only find boards for panasonic tx42-p42x20 B but my modelo is E, from Europe.
    Is ok for my tv?
    I send you photo:
    THANKS AGAIN!
    Re: Panasonic tx42-p42x20E problem
    Definitely A board. Looking at the service manual the B version will operate the tv and all the eeproms and flash chips have the same numbers suggesting they're the same. Try it and worst case you may have to transfer some of the eeprom chips over
      I dont see TNP Number on my main...
        What do you see? White sticker or it should be part of the pcb print otherwise take some decent pictures of the board we can zoom in on top and bottom
          Board
          https://imgur.com/gallery/KbEcC
            Board
              Right so if the link is to a folder and all the images are of your board then I can make out TNPH0829 and the white sticker has ME TXN/A1LWUE. So that should mean TNPH0829 Rev. ME or part # TXN/A1LWUE.
              Search that and it comes up as used in TX-P42X20B, X20E ,
              So you could search either of those numbers to find one. There must be an option to select your region maybe someone else will know that.
              http://www.shopjimmy.com/panasonic-t...tx-p42x20b.htm
              http://www.tvparcasi.com/U995,102,pa...main-board.htm
                Jimmy dont open and tvparcasi dont answer...
                And repair It? What i have to change?
                  Unless you're an electronic specialist with equipment to replace BGA chips I don't like your chances.
                  If the Shopjimmy site is blocked you could try phone or email. They only have one of those boards.
                  Otherwise keep searching or go to ebay where you will find Shopjimmy has it listed anyway.
                  http://www.ebay.es/itm/Panasonic-TXN...oAAOSwZ1BXdpvV
                  Toll Free: (877) 881-6492
                  Work: (952) 881-6492
                  EMAIL
                  sales@shopjimmy.com
                  ADDRESS
                  2300 West Highway 13
                  Burnsville, MN 55337
                    EMAIL
                    sales@shopjimmy.com
                    ADDRESS
                    Thanks so much, but It is fnish in B. My model is from Europe, finish in E, different tuner
                      yes.
                      So on the barcode sticker does your part number match up with that of the B?
                      I thought it did unless the photos you have that link for are not of your board.
                        yes.
                        Are from my board, but I don't see the number.
                        So in Spain the model of plasma finish on E
                          I don't understand how you don't see the number, they're your photos and I'm looking at them and I see the number and the same numbers on the "B" version.
                          I see a white sticker in your photo "ME TXN/A1LWUE." and I see the same sticker on the "B" version.
                          Anyway I could be wrong
                            This is your photo, but maybe you're right being cautious as the manuals don't seem to highlight region selection. I'm purely going on if the part numbers match it should work just changing the region or language is a bit unknown
                              Yes, are The same Numbers, but i think that tuner is different. Because otherwise Panasonic make model E and B?
                                I'm out of ideas for you then. If you swapped over ever eeprom and the 48pin flash IC from your board to the replacement it would turn into your old board.
                                Ii did this once using a new Zealand board for Australian , TV channels were different frequencies steps. It worked.
                                The tuner module is the same but the channels and frequency steps are determined by whatever data is on the eeprom.
                                  It should work.
                                  I had an G10E and motherboard died, then bought B (britain) mainboard and it's working, without any problems.
                                    Indeed , it really does not matter. I also repair tv's with a british or german mainboard. Just install the board , factory settings , choose language. In europe it wont even ask for region , only if you use a british mainboard. ( It will ask england or ireland ).
                                    Ps , in the Netherlands they only use HDMI for inputs. Nobody uses the cable anymore...
                                      Originally posted by Hombre View Post
                                      It should work.
                                      I found a good electronic repair in my city..
                                      Any knows which piece I have to change?
                                        Upp
