Samsung PS42A416C1D No Picture
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    I have picked up a Samsung Plasma set with sound but no picture. At switch on in a darken room the screen does not appear to prime.
    I've taken a few readings and will post some photo's tomorrow.
    Panel Label Voltages
    VS 205V, Va 54V, Vsc -190V, Ve 95V
    Board readings
    VS 205V
    Va 54V
    VSCH 50V to 57V fluctuating
    Vscan -99mV
    Vg = 14.9V
    13V_Amp = 12.8V
    D5.3V = 5.33V
    PFC = 402V
    VCC = 15V
    CN807 connector
    STD5V = NC
    VS_On = 3.3V (0V at STBY)
    NC
    PS_On = 0.48V (3.35V at STBY)
    RTN = NC
    D5.3V = NC
    RTN
    RTN
    D5.3V = 5.33V
    D5.3V = 5.33V
    CN809 connector
    1. Vs = 205V
    2. Vs = 205V
    3. RTN = 0V
    4. RTN = 0V
    5. Vg =14.9V
    I can see the potentiometer for adjusting Ve on the X-Main board but not the test point. Also is Vscan = Vsc.
    Edit.
    Led on the logic board flashes constantly at 0.5 sec On, 0.5 sec Off.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung PS42A416C1D No Picture
    Vscan is Vsc yes, also Ve will be on the traces near where it says Ve.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      I would suggest unplugging the buffers and retesting as if Vsc is variating like that it means its trying to start but the controller is it shutting down. If it stays the same you probably just have some shorted fets on the Ymain which is nothing uncommon for this chassis.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Thanks for the pointer. Appreciated. Just for me to be clear, do you mean disconnect the Y buffer board completely from the Y-Main and then give it a try?
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Yes completely unplug the Ybuffer and retest Vs buddy.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Hello ReeceyBurger123,
            With the Y buffers removed completely Vscan = -91mV. So it doesn't look like the buffers are loading it down. Next step will be to remove the Y-Main and start fault finding.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Yeah seems like a Ymain issue to me, these Tv's I dont think use combined ERC so the Ymain cannot damage the Xmain.
              • Kjelds
                • Aug 2016
                • 30
                • Denmark
                Had the same issue on my Samsung plasma after a capacitor blew up and several other components also died. Replaced the Y-sus/Y-main for around £30 with shipping and now it seems to work again.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Pictures of set for future reference. Fault finding needs to be done on the Y-Main,. The Y buffer board has not been reconnected since last test.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    DB after you have diagnosed the Ymain you need to also recap the powersupply. The Samwha Wl and Wb caps on that supply have a habit of failing and if they do the set wont switch on again. So my advise is replace all the known bad caps on the Psu after the Ymain repair
                    • flocko
                      • Nov 2012
                      • 1121
                      From my little black book of Samsung repairs. I list R5032/C5030/D5014 + U5015 as suspect faulty components for the LJ92-01483A Y Sus. not seen one in years.hope this is of help.could have one kicking about in my old stock
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        Hello Flocko, ReeceyBurger123,
                        Thanks for your useful tips which may well have identified the problem. D5014 (UF4007) is short circuit so I'll test the other components you mention. None of the Fets appear to have blown or are short circuit so hopefully not a major build.
                        Will replace the caps in the power supply as suggested.
                        • flocko
                          • Nov 2012
                          • 1121
                          You also need to test all the little green fuses that are scattered about the board,as I recall the components mounted on the heat-sinks were not a problem on this board,just the IC and the few other parts that I listed, but as I say it has been a long time since one of these has come my way.
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            Hello Flocko,
                            C5030 (100uF 35V) tests out of circuit both ESR & value are OK but will replace it anyway.
                            R5032 I cannot for the life of me locate at the moment. There is a C5032 which is an smd cap connected to pin 2 of U5015 (A6252).
                            There are no unaccounted low resistances between U5015 pins to ground. However since I will have to order some parts I may as well also replace it.
                            I did notice that this set has a large number of different types of fuses on board which I have checked out, all OK, but another check would not hurt.
                            • flocko
                              • Nov 2012
                              • 1121
                              The resistor is through hole mounted not SMD as I recall,the PWM switching regulator I would replace
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                Thanks once again Flocko,
                                The capacitor is an smd connected to Pin 2 of U5015 and the stand up resistor is R5037 and is connected to Pin 2 of U5015. R5045 is also a stand up resistor and is connected to pin 3 of U5015. I'll just check them all out.
                                • flocko
                                  • Nov 2012
                                  • 1121
                                  Thats me misreading my own notes.when i checked my little black book it is R 5037 and C 5030 not the SMD cap C 5032 sorry mate. I will be booking in with Specsavers tomorrow for an eye test
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    No worries. Got there in the end. Have ordered the parts. In the meantime I'll check the caps required to be replaced on the power supply and make sure I have sufficient replacements for a swapping out. Thanks once again.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Nice work keep us updated DB
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        Parts arrived and fitted. Set up and running. Will leave it on soak for a while before closing it up.
                                        Will order replacement capacitors for the power supply and fit before moving set on.
                                        Thanks to Flocko and others for their invaluable help and expertise.
                                          09-07-2024, 05:50 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
