LG 60PA6500-LG Troubleshooting
  • codeman_02
    • Sep 2016
    • 4
    Hello
    I really love this forum as its peaked my interest in trying to fix an LG 60PA6500!
    I have read a lot of the other posters who have issues with the same television but all of their troubleshooting does not follow what I am seeing.
    So I pose the following situation.
    Television when plugged in will have a relay click followed by an immediate relay click off. Pause. Repeat.
    The troubleshooting thus far has yielded the following:
    -> Unplug power to X-sus and same issue (Relay on-off)
    -> Unplug power to Y-sys and the TV will click and stay on (no picture) and I would suspect audio (however I am not sure as we had the TV speakers off - optical to a home theatre)
    .. whats interesting about unplugging the Y-sus is that when I get power to the TV it sounds like its making a buzzing or screeching sound like its still getting power from somewhere?
    I looked at the caps on the Y-sus board and they look good and tried to take a multi meter to them all and they look to be good.
    Not sure what else to test/measure to be more sure that its a Y-Sus board that I should be ordering.
    Many Thanks in advance for any advice.
    -Cody
  • codeman_02
    • Sep 2016
    • 4
    Re: LG 60PA6500-LG Troubleshooting
    Bump.. anyone able to help
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      It will be shorted transistors on the Ysus, cheaper to replace the whole board if I recall.
      • codeman_02
        • Sep 2016
        • 4
        Thanks so much! I shall order one and let everyone know how it goes!
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Ok keep us updated.
          • valvashon
            Repair Success! Middle Atlantic UPS2200R-IP
            by valvashon
            Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
            Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
            02-06-2024, 12:54 PM
          • jm1234
            9V relay temperature 40C
            by jm1234
            Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
            I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
            05-09-2024, 03:03 AM
          • edugimeno
            Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
            by edugimeno
            Hi everyone!
            I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
            I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
            This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
            To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
            I respected the polarity, positive to cathode of protecting diode
            So provided all...
            04-18-2024, 01:15 PM
          • MtnManMike
            Samsung UN75J6300AFXZA LCD TV Power Supply Troubleshooting
            by MtnManMike
            I'm hoping to get some help figuring out how to troubleshoot this power supply board. The television is a Samsung UN75J6300AFXZA, version no. UH03. The power supply board has two model numbers on it, L75S1 and BN44-00723C. As far as experience level, I'm familiar with recapping boards in terms of safely going through the soldering motions, choosing suitable replacement parts, and so forth, but as far as understanding the various functions of each part of these TV power supply boards, I am a rank beginner.
            When I plug the TV in, the screen flashes on and off and...
            07-23-2022, 06:43 PM
          • EazyBone
            Qn65q800taa won't start
            by EazyBone
            Did some of the usual troubleshooting.
            Unplug main board connector and back lights come on and stay on and PSU supplies all correct voltages on the legend.
            When you just plug in the TV the PSU relay clicks on and off immediately and then continues to click on and off every 20 seconds or so. The red light on the front flashes once and then 5 to 8 seconds later flashes once again and continues the cycle with the relay.
            I've disconnected each you ribbon cable one at a time and every single T-Con cable one at a time to see if there's any change. No change as long...
            03-20-2025, 12:47 PM
