LG 60PA6500-LG Troubleshooting
  • codeman_02
    • Sep 2016
    Hello
    I really love this forum as its peaked my interest in trying to fix an LG 60PA6500!
    I have read a lot of the other posters who have issues with the same television but all of their troubleshooting does not follow what I am seeing.
    So I pose the following situation.
    Television when plugged in will have a relay click followed by an immediate relay click off. Pause. Repeat.
    The troubleshooting thus far has yielded the following:
    -> Unplug power to X-sus and same issue (Relay on-off)
    -> Unplug power to Y-sys and the TV will click and stay on (no picture) and I would suspect audio (however I am not sure as we had the TV speakers off - optical to a home theatre)
    .. whats interesting about unplugging the Y-sus is that when I get power to the TV it sounds like its making a buzzing or screeching sound like its still getting power from somewhere?
    I looked at the caps on the Y-sus board and they look good and tried to take a multi meter to them all and they look to be good.
    Not sure what else to test/measure to be more sure that its a Y-Sus board that I should be ordering.
    Many Thanks in advance for any advice.
    -Cody
  • codeman_02
    • Sep 2016
    Re: LG 60PA6500-LG Troubleshooting
    Bump.. anyone able to help
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      It will be shorted transistors on the Ysus, cheaper to replace the whole board if I recall.
      • codeman_02
        • Sep 2016
        Thanks so much! I shall order one and let everyone know how it goes!
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Ok keep us updated.
          • CoinCoin88
            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
            by CoinCoin88
            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
            09-15-2025, 03:36 AM
          • PlasMatt
            LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
            by PlasMatt
            I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
            09-20-2025, 06:50 PM
          • jason123
            Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
            by jason123
            Hi there,
            I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
            So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
            I see 2 posts that are relevant:
            https://www.badcaps.net/forum/troubl...j-oled-5-blink
            https://www.badcaps.net/forum/troubl...g-hardware-dev...
            10-29-2025, 02:01 PM
          • valvashon
            Repair Success! Middle Atlantic UPS2200R-IP
            by valvashon
            Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
            Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
            02-06-2024, 12:54 PM
          • jm1234
            9V relay temperature 40C
            by jm1234
            Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
            I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
            05-09-2024, 03:03 AM
