LG 47LN5750 Magic Remote
  • jason123
    • Oct 2015
    • 1136
    Hello TV Gurus,
    I would appreciate your help on the following. I bought a TV from a lady who claimed the Remote is inoperable. It's LG 47LN5750
    Sure enough, it came with a Magic Remote AN-MR400k remote and almost all buttons work except the "OK" or pushing down on the wheel to Select / Enter / OK function.
    Pressing the "1 2 3/ Q.Menu", or "Mic" on the remote, the TV responds on the screen with a message "To use this feature, you must register your Magic Remote"
    Read the manual, held the Home and Back buttons to unpair, then pointed the remote on the TV and press / held the Select (pushing down on the wheel) and no luck.. I don't get the "registration Complete" or "registration Failed".. or .. nothing!
    The lady said she bought another remote and it did the same thing (didn't work)
    Lady I bought the TV from gave me another nugget. She stated that the TV had the main board replaced by LG for early under warranty failure. I opened the TV and it has part number EAX64872106 for a Main board
    Help is much appreciated! thank you
    P.S. the TV works beautifully with a regular LG remote control (yes, an option, but I'd like to know why the Magic Remote is not pairing or working with it)
    Thanks again
  • Diah
    • Feb 2013
    • 6566
    Re: LG 47LN5750 Magic Remote
    try first to reset the remote by Press the home and back button on the remote simultaneously for 5 seconds, you will have the LED on the remote blinks that mean remote rested, after that register it again by pointing the remote towards the television and press the scroll wheel AND “okay” button.
    • jason123
      • Oct 2015
      • 1136
      Thank you for the feedback.. maybe that's my problem.. I thought pressing the scroll wheel is the same as the OK button as well. Can you tell me where the Okay button is if it's different than pressing the scroll wheel?
      The only other thing I can think of, is that maybe when the main board was replaced, LG didn't replace it with the right main board - rather with one that doesn't have the RF transceiver built-in? Could that be? I hope someone could verify that board that I have is indeed for the 47LN5750. I haven't figured out a way to get the TV to report it's own model number (I looked under help, and under Tech Support info.. no luck)
      Thanks again
      • Diah
        • Feb 2013
        • 6566
        i hope this video help you https://www.youtube.com/watch?v=RdCb...ature=youtu.be
        in general magic remote function on - off volume via Infrarot , other taste via Bluetooth. it can be the replacements MB had other version which it need upgrade M. control
        • jason123
          • Oct 2015
          • 1136
          Thanks.. that's the video I'm following. No luck..
          Just upgraded firmware on the main board. That didn't help.
          Could the Bluetooth module be dead? is there a way to test it out? none of my phones find the TV when I search.. but I don't know if they should anyway, even on functional Bluetooth.
          • Diah
            • Feb 2013
            • 6566
            at this case you need to log inside IN_START service menu to check if the Bluetooth turned on.. or you log at AZ_ADJ service menu to check option M.C 1 or 0... and check Bluetooth MAC address if its registered at the service menu or not.
            also can you tell part number for a Main board after EAX64872106 which version 0.1? and the letters label printed over the EAX64872106
            Edit: forget my pervious comment , i just went back to my archive service manuals and found yours set, on page 19 listed you don't have Magic Remote RF signal receiver built in, M.R its delivered with USB Dongle RF receiver. so ask the Lady where are the USB she may thought its of her family storage USB.
            • jason123
              • Oct 2015
              • 1136
              Looks like the version is 1.0
              Any help on how to get to these special menus?
              Thank you again
              • Diah
                • Feb 2013
                • 6566
                you seam didn't read my edit.. take look.. urs set need USB dongle
                • jason123
                  • Oct 2015
                  • 1136
                  Diah
                  Yes, I replied before reading your edits.. in a hurry I guess
                  So My TV has a built-in Wifi and built-in Bluetooth. Manual (http://www.lg.com/us/support-product/lg-47LN5750# ) doesn't seem to mention the dongle (though it makes sense), and it came with the Magic Remote. I will call the lady and find out, but I am having a hard time imagining it would need Bluetooth external with one built-in, unless Magic is different interface than BlueTooth
                  So manual for the AN-MR400 that I found online (http://www.lg.com/us/support-product/lg-AN-MR400#) implies that a Dongle is built-in for the LN5750, see attached. Unless I'm reading that incorrectly - which would not be shocking!
                  I'll dig into the IN_START menu and see what I find..
                  Thanks again
                    You should have one of this INSIDE the TV.
                    LG EBR76363001 (IA6948-00, BM-LDS401) Bluetooth Module
                    http://www.shopjimmy.com/lg-ebr76363...oth-module.htm
                    http://www.shopjimmy.com/catalogsear...?q=LG+47LN5750
                    • jason123
                      • Oct 2015
                      • 1136
                      I do, the xxxxx3001 one
                      • Diah
                        • Feb 2013
                        • 6566
                        Dongle = USB always. same as yours listed photo, ask the lady..
                        • jason123
                          • Oct 2015
                          • 1136
                          Diah, please see the attachment in my last post to you, has page 3 of the manual, and it says "RF Dongle is Built in TV" for my TV's model number... Is that making sense?
                          • Diah
                            • Feb 2013
                            • 6566
                            if you are sure then you have one cable free in the set check all cable if there are one free.. also it should be at the middle front. you can easy take the section out and check after you may have one plug cable missing, and it should had 2 RF on this section one Infrarot and other Bluetooth RF
                              Show us the WHOLE backside of the TV so we can see all the boards.
                              So you do have the Bluetooth module inside the TV and the cables are attached to it..?
                              • Diah
                                • Feb 2013
                                • 6566
                                i read it,, and yours RF external as service manual talking about. not built in.
                                • jason123
                                  • Oct 2015
                                  • 1136
                                  I'm not by the TV now, but yes, one cable has WiFi module and Bluetooth module both connected to the Motherboard (no bent pins or anything odd about the connection, and Wifi is connected to the internet.) TCon, Speakers, IR, and PS card.. nothing else - your usual LG setup.
                                  • Diah
                                    • Feb 2013
                                    • 6566
                                    neither me not near your TV LOL i do believe on the service manual of LG not on S.J
                                    https://www.badcaps.net/forum/attach...5&d=1473193596
                                    • jason123
                                      • Oct 2015
                                      • 1136
                                      I don't doubt you Diah.. I do appreciate the help.. it's just that information is confusing!
                                      I'll update you on the existence of the dongle as soon as I get a hold of the seller
                                      • Diah
                                        • Feb 2013
                                        • 6566
                                        its okay dear friends...if yours mobile Android and it had Infrarot sender such Galaxy S5 you can use apk. Smart Remote from play store or download from here i did uploaded many time as LG. its good to make you go inside service menu IN_START, AZ_ADJ to seeking after MAC address of Bluetooth and also it had IN_STOP, IN_STOP will reset eeprom and TV go stand by state to new reinstall after next turn on. for yours info
                                        • alfatv
                                          LG 47L5700, add RF emitter for magic remote
                                          by alfatv
                                          This is 2011 LG model.
                                          There is an option to add AN-MR200 magic remote, but it requires another dongle connected to TV.
                                          I got a hold of plasma TV from the same year which works with magic remote and comes with so called RF emitter inside TV. I confirmed that it's essential for magic remote operation by unplugging it.
                                          So, the idea is to install this RF emitter into 47LW5700, has anybody tried it?
                                          There is unsoldered connector on main board possibly for it.
                                          Here is ebay listing for this module:
                                          https://www.ebay.com/itm/New-LG-60PZ...7LW6500-UA-55L...
                                          01-05-2021, 12:28 PM
                                        • cstout
                                          DeLonghi AC Remote only accepts 3V
                                          by cstout
                                          Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                                          The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                                          I can't find any schematics...
                                          06-03-2024, 03:53 PM
                                        • Mc_Millian
                                          Toshiba 50lf711u20 fire tv remote not pairing
                                          by Mc_Millian
                                          I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
                                          The Tv model number is: 50lf711u20 Rev B.
                                          I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
                                          I've tried 3 different remotes which should be fully compatible with this TV.
                                          Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
                                          The power button, along with the volume,back,select, and directional...
                                          04-07-2022, 12:15 PM
                                        • edugimeno
                                          HiSense 55A7500F won't obbey to remote after power on
                                          by edugimeno
                                          Hi! I have this TV set that does the following:
                                          1) I press the red power button on the remote
                                          2) The TV turns on normally
                                          3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
                                          4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
                                          Then after it's off, it would again accept the TURN ON from the remote and same again
                                          BUT:
                                          -The remote does show the correct IR beam while observed thru a phone camera
                                          -The TV works fine while using the MiRemote...
                                          03-14-2023, 11:22 AM
                                        • rustinjust
                                          Please help, where can I get a remote for my subwoofer?
                                          by rustinjust
                                          I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                                          Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                                          Is there...
                                          10-28-2023, 03:43 AM
