Hi all! I have a Vizio P50HDM. I can turn the power on and the power will stay on, but there is no picture. I've taken some voltage measurements with power plugged in but TV off, and then with TV turned on. Please help me diagnose!
Power Supply (IMG_3751)
CN806 Voff Von
VS 0.78 190v
VS 0.78 190v
VS 0.78 190v
NC 0 0
GND 0 0
GND 0 0
GND 0 0
GND 0 0
Va 0.56 58v
Va 0.56 58v
CN805
GND 0 0
GND 0 0
5vctrl 0 5.11
5vctrl 0 5.11
CN804
9Vsc 0 8.94
9Vsc 0 8.94
GND 0 0
5Vsc 0 5.11
5Vsc 0 5.11
5Vsc 0 5.11
GND 0 0
GND 0 0
CN803
5Vsc 0 5.13
5Vsc 0 5.13
5Vsc 0 5.13
GND 0 0
GND 0 0
GND 0 0
12Vsc 0 11.96
12Vsc 0 11.96
GND 0 0
GND 0 0
12Vfon 0 11.94
12Vfon GND 0 0
SW502
30v 0 5.14
24v 0 0
CN809
9Vsc 0
GND 0
CN802
30v 0 24.0
24v 0 0
GND 0 0
GND 0 0
CN801
ACD No wire
RLY-ON 0 4.60
5Vsb 5.05 4.90
GND 0 0
Vs-ON 0 4.60
5VD No wire
NC No wire
Ysus (IMG_3748)
Fuses (I pulled them out and tested for continuity)
FS2 OK
FS3 OK
P11
+5V 0 5.02
+5V 0 5.02
GND 0 0
GND 0 0
GND 0 0
GND 0 0
NC 0 0
+VA 0.56 60.2v
+VA 0.56 60.2v
NC 0 0
+VS 0.79 193v
+VS 0.79 193v
P6
GND 0 0
GND 0 0
GND 0 0
GND 0 0
+5V 0 5.06
+5V 0 5.06
+5V 0 5.06
+5V 0 5.06
P3 (this one is strange - negative voltage readings? guessing most pins need a scope, but voltages are still confusing for GND and +5V??)
GND 0.08 -10.3
+5VF 0.08 -5.5
GND 0.08 -5.5
VNSC 0.08 -11.3
OC1 0 -6.9
OC2 0 -10.9
DATA 0 -7.2
STB 0 -7.3
GND 0.08 -11.9
ELK 0 -10.9
GND 0.08 -11.9
P2
GND 0 0
GND 0 0
+5V 0 5.06
+5V 0 5.06
VA 0.55 60.4v
VA 0.55 60.4v
-Vy Test Points (also strange negative voltage reading) (IMG_3748b)
-Vy TP (top) 0.12 113.9v
-Vy TP (bottom) 0.12 -83.9v
Connection from Ysus to YDRV boards (also strange negative voltage readings) (IMG_3747)
Top 0.08 -12.3v
Middle 0.02 59.5v
Bottom 0.08 -12.3v
Zsus (IMG_3752)
P152
GND 0 0
GND 0 0
+5V 0 5.06
+5V 0 5.06
NC 0 0
VA 0.55 60.5v
VA 0.55 60.5v
P153
VA 0.55 60.5v
VA 0.55 60.5v
+5V 0 5.06
+5V 0 5.06
GND 0 0
GND 0 0
I know from reading the other threads IPMs are the usual cause. Is that the case here based on these readings? Or do I just have bad panel? or?? Let me know what seems out of the ordinary and your thoughts!
Thanks,
--Dave
CN806 Voff Von
VS 0.78 190v
VS 0.78 190v
VS 0.78 190v
NC 0 0
GND 0 0
GND 0 0
GND 0 0
GND 0 0
Va 0.56 58v
Va 0.56 58v
CN805
GND 0 0
GND 0 0
5vctrl 0 5.11
5vctrl 0 5.11
CN804
9Vsc 0 8.94
9Vsc 0 8.94
GND 0 0
5Vsc 0 5.11
5Vsc 0 5.11
5Vsc 0 5.11
GND 0 0
GND 0 0
CN803
5Vsc 0 5.13
5Vsc 0 5.13
5Vsc 0 5.13
GND 0 0
GND 0 0
GND 0 0
12Vsc 0 11.96
12Vsc 0 11.96
GND 0 0
GND 0 0
12Vfon 0 11.94
12Vfon GND 0 0
SW502
30v 0 5.14
24v 0 0
CN809
9Vsc 0
GND 0
CN802
30v 0 24.0
24v 0 0
GND 0 0
GND 0 0
CN801
ACD No wire
RLY-ON 0 4.60
5Vsb 5.05 4.90
GND 0 0
Vs-ON 0 4.60
5VD No wire
NC No wire
Ysus (IMG_3748)
FS2 OK
FS3 OK
P11
+5V 0 5.02
+5V 0 5.02
GND 0 0
GND 0 0
GND 0 0
GND 0 0
NC 0 0
+VA 0.56 60.2v
+VA 0.56 60.2v
NC 0 0
+VS 0.79 193v
+VS 0.79 193v
P6
GND 0 0
GND 0 0
GND 0 0
GND 0 0
+5V 0 5.06
+5V 0 5.06
+5V 0 5.06
+5V 0 5.06
GND 0.08 -10.3
+5VF 0.08 -5.5
GND 0.08 -5.5
VNSC 0.08 -11.3
OC1 0 -6.9
OC2 0 -10.9
DATA 0 -7.2
STB 0 -7.3
GND 0.08 -11.9
ELK 0 -10.9
GND 0.08 -11.9
P2
GND 0 0
GND 0 0
+5V 0 5.06
+5V 0 5.06
VA 0.55 60.4v
VA 0.55 60.4v
Top 0.08 -12.3v
Middle 0.02 59.5v
Bottom 0.08 -12.3v
Zsus (IMG_3752)
P152
GND 0 0
GND 0 0
+5V 0 5.06
+5V 0 5.06
NC 0 0
VA 0.55 60.5v
VA 0.55 60.5v
P153
VA 0.55 60.5v
VA 0.55 60.5v
+5V 0 5.06
+5V 0 5.06
GND 0 0
GND 0 0
Thanks,
--Dave
