Panasonic Plasma TH-P42V20A – 13 Blinks
  • Dave-2
    • Aug 2016
    Hi Guys,
    I'm trying to diagnose a Panasonic 42” plasma TH-P42V20A which is displaying 13 red blinks.
    It started to fail some months ago. Initially it would power on fine and after maybe 1-2 hours of watching it would appear to power down (accompanied by sound of the power board relays clicking), and after 1 or 2 seconds then power on again. Over time, and perhaps in different temperature conditions, the random switching off events began occurring sooner after powering on, became more frequent, and the periods of power down became longer. Now it is difficult to get the unit to display a picture at all. When powering on it clicks and displays the usual fast blinking green LED as its starting up, and then the LED is solid green but there's no picture. After a few mins it displays 13 red blinks. I have the service manual for my exact model but its ‘Power LED Blinking Timing Chart' only lists up to 12 blinks. I've read the thread at https://www.badcaps.net/forum/showthread.php?t=22926 which suggests a comms error at IC8001 but my TV has a different model main (A) board and does not have an IC8001. My A board is Part Number: TXN/A1LAUA42, PCB Number: TNPH0845 BA (2)(A). The No Picture fault diagnosis chart in the service manual also suggests that if the OSD is NG yet the LED on both the SC board and SS board are on (which they are in my case) then it's the A board that's faulty.
    I've tried heating the power and A boards with a heat gun whilst the TV is operating in an attempt to change the state of dry joints but there's no change. I've now pulled the A board out to inspect for dry solder joints and reflowing as required. However any suggestions on the likely problem area on the board would be much appreciated! Failing reflowing joints fixing the problem, should I just replace the A board, or is there a chance the A board not at fault? The caps on the power supply board look fine, and functionally it seems that the power board is OK?
    Thanks in advance…
    Cheers,
    David.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic Plasma TH-P42V20A – 13 Blinks
    Going to be A board and at a guess I'm thinking failed solder under a bga chip. Statewide appliance spares show available at $360. Other options is find a broken tv to scrap. There is/ was a 50" in SA ebay maybe see if they will pull the boards and ship.sell what you don't need
    Then use the A board but will need to swap some eeproms and flash chips from your dead board to make it a 42" version
    • Dave-2
      • Aug 2016
      Thanks TW2005. Yes there is one BGA on the board which I had my suspicions about and of course is harder to inspect/rework. There's no socketed flash/PROM devices on my A board so swapping firmware to a second hand unit looks more difficult. I read in the service manual of the data copy process to/from SD card when changing the A board, but I imagine this is user settings only (not firmware)? Besides, in my case as the screen is not running that process would be difficult to run!
      MXM Electronics appear to have one at http://www.mxmee.com.au/index.php?ro...roduct_id=1341 If the part number is exactly the same can I safely assume it's a drop in replacement?
      Cheers,
      David.
      • tw2005
        • Oct 2011
        • 6458
        Looks to be right. There's about 4 or 5 chips probably only 2 would need changing just a matter of either desoldering them anyway board is easier .
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • stecos
          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
          by stecos
          Hi everyone!
          I happened several times, in the search for help from the web, to consult this very interesting forum.
          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
          Having said that I come to the gist of my post on the forum as the title suggests.
          For my passion for technology I'm now collecting several...
          11-28-2022, 11:39 AM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • Biruslapio
          Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
          by Biruslapio
          Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
          It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
          It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
          02-16-2021, 09:44 PM
          After all of...
          07-13-2024, 08:14 PM
