JVC LT-32A61SU bad picture
  • coojoe_213
    • Nov 2015
    • 105
    • bulgaria
    Hi all.
    I have this tv, when i turn on tv without signal, everything is perfect /i have perfect blue screen, perfect ''menu panel''/.
    When i put the cable for tv, or then i connect dvd or blu ray player, the picture is.....some of solarized or ... i don't know...., but the menu panel is still perfect.
    I thing..., may be chip AS15-F on the t-con, but i don't have this chip on the t-con.
    On the t-con i have 32 pin chip MAXIM1518E.
    Should I check the Tcon or the Mainboard first?
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: JVC LT-32A61SU bad picture
    Post a phoro of your circuit boards.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Let's see pics of your symptom please.
      • coojoe_213
        • Nov 2015
        • 105
        • bulgaria
        Pics 4, 5 and 6 of first post is a pictures with symptoms /bad pictures/.
        Here is a serv. maunal:
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          it does look like a Tcon fault but better to see what others think. There are various voltage points on the Tcon board which you could measure the volatges at.
          V3D3, V5V, VGHC, VGH, V2D5 etc.
          • coojoe_213
            • Nov 2015
            • 105
            • bulgaria
            All GAMMA voltages is no more than 1.30V (0.98, 1.13, 1.26, 0.18 V etc), this is may be bad.
            Here is voltage on my T-con:
            2VS/DC- 4.91V
            VGHC-26.1V
            VGH-26.6
            VGL-6.1V
            VCOM2-6.1V
            COMF2-6.1V
            VIN-3.31V
            V2D5-2.5V
            AVDD-13.6V
            V5V-5.0V
            V3D3-3.3V
            ASYC RST-3.3V
            LVDS- 3.23V
            VGMA- 12.91V
            V2REF1 - 2.5V
            REF/F1-12.86V
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              The supply voltages look reasonable and the reference voltages appear to be there. Looks like you may be right and the gamma chip is faulty.
              • coojoe_213
                • Nov 2015
                • 105
                • bulgaria
                Thanks for reply, i'll buy this one from aliexpress
                http://www.aliexpress.com/item/MAX15...e-b1b118556ea8
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  That center area of the chip will be soldered onto the pcb. Do you have the equipment to remove it?
                  • coojoe_213
                    • Nov 2015
                    • 105
                    • bulgaria
                    Yes, i know. I find in Bulgaria this chip. Saturday will be here. I'll post a pics.
                    • coojoe_213
                      • Nov 2015
                      • 105
                      • bulgaria
                      The problem is on main board. I find worked t-con, and when i replaced t-con, the problem was the same. Thanks all for help.
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        not sure how mainboard can do that.thats a gamma regulator issue.
                        i suspect your replacement tcon is bad too.
                        • coojoe_213
                          • Nov 2015
                          • 105
                          • bulgaria
                          No, i told you. I find anather one, which work, absolutly same number part, and the problem was same. What you thing about AV Processor on main board?
                          • Kilroys
                            • Feb 2014
                            • 70
                            • Sweden
                            Or could it be noise in the picture as the service informations said
                            • coojoe_213
                              • Nov 2015
                              • 105
                              • bulgaria
                              Thanks a lot. Excellent information!!!
                                LCD LED TV Service Menu Codes
                                ALL LCD LED TV SERVICE MENU CODES
                                Service Menu Code with Board Name
                                China Universal Board / Jumper Board Service Menu Code
                                Changhong Ruba Service Menu Code
                                Ecostar LED TV Service Menu Code
                                Orient LED TV Service Menu Code
                                Haier LED TV Service Menu Code
                                TCL LED TV Service Menu Code
                                Samsung LED TV Service Menu Code
                                LG LED TV Service Menu Code
                                Videocon LED TV Service Menu Code
                                Supra LED TV Service Menu Code
                                Toshiba LED TV Service Menu Code
                                Symphony LED TV Service Menu Code
                                Veste/ LED TV Service Menu Code...
                                10-31-2024, 03:58 AM
                              • Fly_Among_Stars
                                VIZIO E70-E3 Half picture with half TCON
                                by Fly_Among_Stars
                                I have a VIZIO E70-E3.
                                Symptoms: Black screen, no picture, but LED backlights are working.
                                I probed the power board and voltages are as listed on the board.
                                Main board appears fine, too.
                                I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                There are two separate ribbon cables feeding the LCD.
                                If both are connected, the screen is black.
                                If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                04-24-2023, 08:20 PM
                              • Ierwin
                                Philips 58PUS7805 Menu working but no/weird picture from video sources
                                by Ierwin
                                I got a 58pus7805 that shows some weird behavior.
                                The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
                                However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
                                I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
                                I managed to install the latest official firmware by holding the control button while plugging...
                                03-10-2024, 12:50 PM
                              • Mgiffune
                                by Mgiffune
                                06-09-2024, 10:28 AM
                              • shelby5041
                                Samsung LCD TV no picture backlight on no 12v at tcon
                                by shelby5041
                                hi
                                i have a samsung lcd tv
                                it powers on with sound and backlight but no picture
                                all voltages from PS are good 12v 3.3v and 5v
                                whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                                i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                                no 12v at the tcon fuse
                                i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                                the odds of having 2...
                                10-08-2021, 08:21 AM
