Samsung ue32h4510 turns on and off randomly (bad power board ?)
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8119
    Re: Samsung ue32h4510 turns on and off randomly (bad power board ?)
    That problem was in this thread: https://www.badcaps.net/forum/showthread.php?t=47479
    I hooked up my oscilloscope to the secondary and made sweep like very slow. When I heated the specific area (that didn't take very long), the voltage rail became unstable (so voltages would go up and down fast) then the PSU quit.
    One more thing: the voltage on the main filter cap is staying put at 316V when the PSU shuts down?
    Next, the PWM. If you follow the voltage from the main filter cap to the PWM on the backside of the board (goes through J809), there are a bunch of resistors it has to go through, maybe one is bad and the PWM loses VCC?
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      Checked all of the resistors and they read OK. Both the 4704 ones (4.7 mega ohms) and the 243 ones. I might actually focus on that inductor again, as it's the only giveaway that something's wrong there, since it makes that random whizzing noise. I know that it's acceptable for coils to make a certain amount of noise (especially when caps start going bad and no longer filter), but this one definitely sounds off. Also, turning the backlight all the way down didn't change anything: TV still shut down when I touch the supply or flex the TV's chassis.
      Wattevah...
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        New power board arrived today and it works perfectly. I'd still like to be able to fix the original one so I can at least sell it to gain some more money...it won't be easy now that I no longer have the tv to test it on, since it won't go unstable with no load on it.
        Wattevah...
          I suspect something is bad in the primary drive circuit, there is one small startup/running electrolytic cap in the primary side that you can check the ESR, Voltage on it.
          it can also be something in the secondary side that cause the power supply to be unstable. Also see the DCV on the main filter cap is fluctuating a lot or not too.
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            I actually REPLACED that cap and it wasn't that, so I still suspect the problem is in the secondary...haven't had time to mess around with it anymore - the Samsung power supply BN96-03058 in my other post is far more urgent, as it's been sitting for a week now due to lack of both parts and time (my shop is not to well stocked and we're pretty far from the nearest electronics shop) )
            Wattevah...
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8119
              The only thing you can't test, are the backlights. Other than that, it doesn't matter of having the rest of the TV.
              As mentioned before a few times now, we need to see if the voltage on the main filter cap and on the PWM stays stable.
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                #27
                Filter cap: yes, stable at around 316v even when the secondary starts having issues. PWM - sits at 108v with no LEDs connected (and at 87-88v WITH the LEDs attached), but starts randomly falling after a few minutes of runtime or when I move the board or the whole TV (also accompanied by the electrical noise which seems to be coming from that choke).
                Wattevah...
                  Sounds like you have bad solder joints on the board.
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    #29
                    That was my first instant guess, but after reflowing what I thought was most of the components, the problem was still there. I'll try that coil again, following CapLeaker's suggestion of pulling it out and thoroughly cleaning the holes first (even though I DID remove the coil once before soldering back in place, I didn't pay too much attention to removing every last bit of solder left in there, so I might still have a dodgy joint there).
                    Wattevah...
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8119
                      While you are at it, do the same thing to DM861C.
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                      • C152Heavy
                        Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                        by C152Heavy
                        Summary for TL-DR readers:
                        • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                        • Have obtained Samsung schematic & service documents - Can upload if helpful.
                        • Have read ALL applicable threads
                        • C1818 and CP820 replaced as low hanging fruit
                        • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                        • VCC pin (18) of PFC...
                        01-11-2023, 02:53 PM
                      • Destroyer-Br
                        [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                        by Destroyer-Br
                        I'm working on an Acer Nitro 5 unit with the following specs:
                        • Motherboard: LA-J871P Rev: 1B
                        • Model: Acer AN515-55-59MT
                        • S/N: NHQ7JAL00403906A973400
                        • SNID: 03902728734
                        Initial Issue
                        The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                        After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                        04-17-2025, 08:18 PM
                      • Nicktronic
                        Samsung Power Supply Board BN44-00874F
                        by Nicktronic
                        Hey everyone,
                        This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                        Anybody...
                        03-17-2025, 06:20 AM
                      • Dani_2024
                        by Dani_2024
                        10-28-2024, 05:06 PM
