Vizio M420NV no backlight
    • 12276
    • U.S.
    Re: Vizio M420NV no backlight
    There's some other things you can test on the mainboard, looks like you need to know why the mainboard isn't sending the bl_on signal.
    • sricechex
      • Mar 2018
      • 17
      Thank you for finding that video. I haven't gotten to the unit this evening yet, I'll keep you posted.
        If you can force the backlights on using the resistor, then you can disconnect just the BL-ON signal wire going back to the main board and put all the connectors back in place, and then keep the pull-up resistor for the BL-ON pin on the power supply board in place, power up the TV and everything should then work normally if the BL-ON signal is the only problem on the main board.
        • sricechex
          • Mar 2018
          • 17
          Nothing happens when I disconnect the motherboard from the power supply and plug in.
          In regards to the resistor test in post #8, my board lists no "PS_ON," as far as I can see. Are any of these other pins indicators of a ps_on?
          • sricechex
            • Mar 2018
            • 17
            The backlights do come on with a 1k between BL_ON and 5VSB!
              • 12276
              • U.S.
              #26
              Ok, you could test some of the components on the mainboard if you want to dig deeper, where to start is the question.
              • sricechex
                • Mar 2018
                • 17
                This tv is certainly not worth a $100 mainboard ($25 pawnshop special), but in that I got it just for the learning, I'm tempted to swap the eeprom, if I can have some confidence that a failed eeprom is the culprit.
                Any thoughts on further testing on the mainboard?
                I greatly appreciate your input, nomoresonys and budm. You guys are kind to lend your expertise
                  • 12276
                  • U.S.
                  #28
                  I'll try to help but it will be slow, not too good with troubleshooting mainboards.
                    • 12276
                    • U.S.
                    #29
                    If you trace the bl_on wire from powersupply back to mainboard so you know which pin it is, unlpug connector at mainboard and see what voltage you have there, I always unplug tv first then unplug connector from mainboard then plug tv back in, to try not getting any strange surges.
                      • 12276
                      • U.S.
                      #30
                      https://www.techwalla.com/articles/h...-board-of-a-tv
                      Rough guide on mainboard testing.
                      • sricechex
                        • Mar 2018
                        • 17
                        Great, dude, thanks. I'll let you know if I learn anything useful for future projects!
                          • 12276
                          • U.S.
                          #32
                          https://www.youtube.com/watch?v=Sghh8BK5zIw Testing video, looks like hes testing eprom voltages, voltage regulators etc.
                            • 12276
                            • U.S.
                            #33
                            https://elektrotanya.com/?q=keres Put your model number in there, see if they have a service manual.
                              • 12276
                              • U.S.
                              #34
                              Vizio 32 inch (VA320M) Eco 1080p black screen
                              There's a thread there by KuDaH with some info.
                                • 12276
                                • U.S.
                                #35
                                There's quite a few threads on this model, put M420NV in the search up there on this page.
                                  Did you try post #23?
                                  • sricechex
                                    • Mar 2018
                                    • 17
                                    Budm, that's what I did this morning, and the backlights work great! Ran off my Raspberrypi just fine. Thanks for the input.
                                    I had only a minute before work, so haven't been able to play with the other posts yet. I want to see if I can gain some experience isolating the culprit component(s) with some more precision.
                                    If it promises to be too frustrating or expensive, I'll just jam that resistor back in.
                                    That will keep my sunk cost at $25.01...not too shabby.
                                      So all the TV functions are OK then?
                                      We can use other signal as the BL-ON.
                                      • sricechex
                                        • Mar 2018
                                        • 17
                                        I haven't made time yet to try all functions, just menu functions, and successful HDMI input. When I get back to it I'll try different input and audio.
                                        Are you thinking of any specific functions?
                                        Where would you suggest sourcing the other signal?
                                          You can use T-CON ON signal for BL-ON.
                                          • howardc64
                                            Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                                            by howardc64
                                            Problem
                                            Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                                            Model & Board Pics
                                            Conflicting Spec
                                            Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                                            https://www.shopjimmy.com/vizio-gj-2k1...
                                            10-10-2024, 01:16 PM
                                          • triplefour
                                            by triplefour
                                            09-13-2023, 10:43 PM
                                          • JaquesPratt
                                            Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                            by JaquesPratt
                                            I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                            This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                            07-16-2024, 01:04 AM
                                          • Jidis
                                            Need T-Con Advice (Vizio P602ui-B3)
                                            by Jidis
                                            I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
                                            He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
                                            09-22-2025, 05:10 PM
