LG 37LG6000 Scarlet Problem
  • sandrabrnelic
    • Mar 2012
    • 34
    • Croatia
    Hi, i have problem with LG Scarlet TV. When i plug power on, it turns's ON itself without pressing button on remote, red led blinks 3 times, then it goes white, and after that it goes to dim white. Turn on tune is heard throug speakers. Backlight turns on but there is no picture and after that backlight start to turn off/on itself. It's on 2-3 seconds and off 2-3 seconds. TV isn't responding to remote commands. Please help.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 37LG6000 Scarlet Problem
    Seems like a PSU problem at first thought.....Post pics of TV back with covers removed.
    • sandrabrnelic
      • Mar 2012
      • 34
      • Croatia
      I don't think so, i have measured all voltages +24 for backlight is OK, +16 is OK, +12 is OK, +5V is OK, +5Vstandby is OK, +3,3V OK, +1,8V OK, +1,2V OK. When i remove cable between IR sensor board and main board then TV isn't starting by itself. So i think maybe problem is somewhere on IR sensor board but i can't track it because there is no schematic of IR board in service manual that i have found on web.
      http://www.electronica-pt.com/esquem...89d-lcd-16072/
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        OK...So could we see a pic of the IR board, then??
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          I would suspect a firmware or main processor issue instead of the IR board.
          A working TV? How boring!
          • vinceroger69
            • Mar 2012
            • 6714
            is this the ir board used in your set
            http://www.ebay.co.uk/itm/EAX4343960...0AAOxyThVTZ4Ve
            • sandrabrnelic
              • Mar 2012
              • 34
              • Croatia
              yes, it looks just like this one
              • sandrabrnelic
                • Mar 2012
                • 34
                • Croatia
                Or IC802 (WT61P8-Flat Panel Display Control Sub-MCU), or IC801 eeprom ... i don't know where to start ...
                Sometimes happens that TV starts ok and works, and in this case it will work ok until i turn it off.
                • sandrabrnelic
                  • Mar 2012
                  • 34
                  • Croatia
                  Update ...
                  TV is starting itself even when i disconect cable between mainboard and sensor/led/keys boards. I believe problem is located on mainboard that is starting without any buttons pressed/connected, after that backlight starts blinking, signals from inverter are OK, it blinks because DIM signal goes from 0 to 3V and back. INV_CTL and PANEL_ERROR_DET signals are OK.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    as per post 5 maybe a eeprom issue what is your mainboard numbers etc.
                    • sandrabrnelic
                      • Mar 2012
                      • 34
                      • Croatia
                      you mean hardware problem with eeprom or just problem with eeprom content, main eeprom or sub-MCU eeprom, and where can i find sub-MCU .bin ?!
                      mainboard is LD89A/D/F EAX39192001(14)
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        is there another number on it something like EBU42372382?
                        • sandrabrnelic
                          • Mar 2012
                          • 34
                          • Croatia
                          yes, on the sticker with barcode
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            what is that number? as theres loads of diffrent mainboards
                            • sandrabrnelic
                              • Mar 2012
                              • 34
                              • Croatia
                              It's same number - EBU42372382 !
                              • sandrabrnelic
                                • Mar 2012
                                • 34
                                • Croatia
                                I have updated firmware and now everything works fine. I used notebook with serial cable and hyperterminal to be able to do this because every other method didn't work for me.
                                Here is procedure that i followed (copied from other forum):
                                To recover an apparently dead lg set you'll need
                                * a computer with a serial port
                                * a null modem cable
                                * a terminal emulation program with file transfer capability (zmodem protocol)
                                * a good firmware file (*.epk)
                                * a little care
                                * a lot of patience
                                If you don't understand the meaning of anything in this list it's better you call lg service
                                Warning, incorrect operations could irreparably damage your set
                                This is the sequence of actions:
                                1. turn off the tv (by removing the power cable or using the on/off switch, all leds must be off)
                                2. connect the service port on the tv to the computer serial port with a null modem cable
                                3. start the terminal emulation program an set the speed at 115200, 8 data bits, no parity, 1 stop bit, no hardware or software handshake
                                4. turn on the tv and at the same time press Esc on the keyboard. It may be necessary to press Esc more than once
                                5. if everything goes well, you'll be greeted by a "Mstar #" prompt (here you can write help to obtain a list of available commands in the u-boot bootloader)
                                6. issue the swuz command (software upload zmodem). the tv will await the file
                                7. in the terminal emulation program select the correct firmware file (.epk) to send to the tv
                                8. don't touch anything and hope there's no power cut (it's a long process!)
                                9. once the file has been successfully transferred, turn off the tv
                                10. disconnect the serial cable
                                11. turn on the tv and hopefully it will work
                                The only difference is that my TV didn't have "Mstar" prompt, after pressing esc it gives "douglas" prompt, everything else was exactly as described here.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  Glad you managed to update the firmware and thank you for the instrucions too could you please upload the firmware files you used? as thses may help other members out too.
                                  • sandrabrnelic
                                    • Mar 2012
                                    • 34
                                    • Croatia
                                    Here is .epk file for 37LG6000 that i have used, it's 3.49.0 version of firmware. I'm not sure but i think it's good for all LG6000 series TV's.
                                    And one more thing that i want to mekae clear ... in step 7. you need to click on "transfer" and then choose "send file ..." if you're using Hyperterminal, after that you need to choose zmodem protocol.
                                    • imheretofixmytv
                                      • Dec 2020
                                      • Bulgaria
                                      * a little care
                                      * a lot of patience
                                      I fixed it!
                                      my TV's problem was that when you turn it on, the only thing that happens is the power indicator gets white, and the backlight turns on. When you turn it off, it takes about 10 seconds to respond until it finally turns off.
                                      It bugged when i enabled the setting for the startup sound, and then when i restarted the tv, it didnt want to start.
                                      The steps i did to fix my problem are pretty much the same as in this guide, but in my case when i turned on the tv (step 4) to connect, the tv restarts after at most 1 second and then the connection gets lost. Then it connects again and then it restarts again etc. So i had to press escape many times until it stopped restarting, and then i could finally write commands.
                                      Another thing was that i tried many terminal emulation programs, but the one which worked for me was Terra Term.
                                      Terra Term link: http://hp.vector.co.jp/authors/VA002416/teraterm.html
                                      How to use the program: https://www.youtube.com/watch?v=ofhKCXVbu-0
                                      i hope this helps anyone
                                      • MzaNike
                                        • Dec 2024
                                        • Deutschland
                                        The username was different, but it worked.
                                        Thanks a lot for sharing!!!!
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • Zeonalbasta
                                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                          by Zeonalbasta
                                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                          09-13-2024, 01:17 PM
                                        • Gibon378
                                          Problem with stopping audio and video for no reason
                                          by Gibon378
                                          PC Specs:
                                          • CPU: Ryzen 5 1600
                                          • GPU: GTX 1080 Palit JetStream
                                          • MOBO: ASRock ab350 PRO4
                                          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                          • PSU: XFX 650W (don't remember what model)
                                          • OS SSD: ADATA SP920
                                          • OS: Windows 10 21H2
                                          Problem description:
                                          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                          11-19-2022, 09:41 AM
                                        • perzyk23
                                          Lenovo T580 - LCD Panel problem - error 0288
                                          by perzyk23
                                          Good morning,
                                          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                          10-25-2024, 12:42 AM
                                        • lazaro.089
                                          Asus Zephyrus M16 / GU603ZW problem
                                          by lazaro.089
                                          Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
                                          CPU: Core i9-12900H
                                          Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
                                          Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
                                          The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
                                          08-26-2025, 06:33 PM
