Forcing on Power Supply with PS_ON
    Re: Forcing on Power Supply with PS_ON
    Originally posted by tech2014
    The voltage is 4.5V on pin 3 of the PFC controller IC. Here are some pics of the PFC circuit.
    That is OK, the trip point is if it is below 1.40V, so next you need the scope to look at the Drive Output pins GD-M 19, GD-S 17.
    • tech2014
      • Aug 2014
      • 807
      ok I will check those. I don't have an isolation transformer, will it be safe to use my scope as long as I have it is grounded on primary ground.
        NOPE! you need to plug what you are working on into the completely isolate AC outlet of the isolation transformer.
        If you put you scope GND on the primary circuit ground (negative leg of the main cap) you will see nice sparks and smoke.
        • tech2014
          • Aug 2014
          • 807
          HAHA glad I asked lol. Any idea where I can find one on eBay?
          • Andyy
            • Aug 2016
            • 28
            If your scope is battery powered, you won't need an isolation transformer (effectively the scope is a fancy glorified multimeter, whose ground reference is floating).
            But an isolation transformer is good anyway for safety's sake.
            • tech2014
              • Aug 2014
              • 807
              My scope is not battery powered so I am SOL. I measured the 3 parts on the heatsink in the PFC circuit, 1 diode and 2 FETs. They all measure ok in circuit. I also measured all the surface mount low ohm resistors and diodes and they all measured good. So only other thing is the PFC IC, unless I missed something?? I watched a video on youtube regarding this p/s. The tech used a 220 ohm resistor from the PS_ON pin to ground. I just used an alligator clip connected to ps_on pin and other end connected to secondary ground. It shouldn't make a difference since the voltage is low enough shorted directly to ground.
                You already know that the PS-ON signal (ACTIVE LOW) is fine otherwise you will not have VCC for the PFC IC, that VCC for PFC is fed through a switched Transitor which is turn on when PS-ON signal is present.
                • Andyy
                  • Aug 2016
                  • 28
                  Borrow a car battery and inverter
                    Plug the TV into a UPS with TRUE SINE wave that is not connected to the outlet and safety GND.
                    Running Scope with Battery will make your scope GND at line potential, still not safe if you touch scope GND/chassis and Earth, it is the same as cutting off the Safety GND pin of the power plug of the scope.
                    You want to float the load, not the instrument, your scope has exposed metal, you meter is all plastic.
                    You must remember this, the primary side circuit GND ref. (Negative leg of the main filter cap) is not at GND potential with ref to safety GND!
                    Differential probes come in handy when work on the HOT side of the circuit, that is what I use in the lab at work.
                    Safety first!
                    • tech2014
                      • Aug 2014
                      • 807
                      I am going back to school in September, so I cannot afford to drop hundreds of dollars on a differential probe, but I can not afford not to have an isolation transformer. I did find one on eBay. Made an offer, waiting for response.
                      I agree budm, safety first.
                      • tech2014
                        • Aug 2014
                        • 807
                        So I removed the 2 mosfets in the PFC circuit and tested them. I put my (-) on the source pin and the (+) on the drain pin. Reads OL, which is normal. I then touched the (+) to the gate for a second, then back to the gate. Should I not get a reading close to 0? I get 0.4V. When I put my finger between the gate and source, the voltage goes back to OL.
                        Is a voltage drop of 0.4V ok, or is it too high?
                          MOSFET should usually shorted out when they fail, and as I indicate, I doubt that both of them failed at the same time.
                            by sam_sam_sam
                            03-31-2024, 02:12 PM
                            by sam_sam_sam
                            07-01-2024, 06:34 AM
                          • JimBanville
                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                            by JimBanville
                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                            09-13-2023, 07:21 AM
                          • CMCM
                            Russound CA4 Power Supply Repair
                            by CMCM
                            Hello Everybody,
                            Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                            Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                            The outputs marked 12v and 20v are all measuring only 1v.
                            The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                            The capacitors physically look clean (no bludgesor leaks) and...
                            07-03-2025, 01:12 PM
