LG 42pq30 power supply poof
  • splatee
    • Jul 2016
    • 95
    Picked up a LG 42pq30 plasma up that had a turn on issue. After troubleshooting the power supply found a fuse was open an replaced it. Plugged it back in and poof power supply went up in smoke. Looks like a few diodes and a couple resistors went and an IC. I had the other boards disconnected from it so those are ok. Looks like i will be needing a new power supply.
  • dkneyle
    • Dec 2013
    • 441
    Re: LG 42pq30 power supply poof
    Ah yes, the old syndrome of $50 worth of semi-conductors going open circuit to protect the 15c fuse!
    • splatee
      • Jul 2016
      • 95
      Have replacement power supply ordered and should be here in a couple of days. Hopefully all goes well. I really didn't plan on putting a bunch of money into this tv and the wife isn't too thrilled either.
      Thank you
      • splatee
        • Jul 2016
        • 95
        Replacement power supply installed and working. The only thing is that there is like a peppery pixel noise on the screen. Sort of looks like pixels are not firing correct. It is not really noticeable from viewing distance but up close can see it. I wonder if the voltage needs to be adjusted slightly. Have not taken measurements. But so far so good.
        • comptek
          • Aug 2013
          • 606
          • uk
          Check and adjust VA and VS voltages
          • maxvalutech
            • Dec 2014
            • 804
            • australia
            Agree get vs va within one volt of what shown on rear of screen. Also look for other trimmers on ysus and take note of position now and then try a bit of a tweak for any improvement. And further just ensure control board connections ribbons clean and properly seated both ends.
            • splatee
              • Jul 2016
              • 95
              Thanks for the help everybody,
              I adjusted the VA and VS to the voltages labeled on the panel sticker.
              VA=60v was 59v
              VS=196V was 191v
              Y-Sus
              -175v
              145v
              Z-Sus
              80v
              There was a slight improvement but still some sparkles. Not sure what else to check. I did all voltages at recommended values
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
                03-31-2024, 02:12 PM
                07-01-2024, 06:34 AM
              • JimBanville
                Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                by JimBanville
                The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                09-13-2023, 07:21 AM
              • CMCM
                Russound CA4 Power Supply Repair
                by CMCM
                Hello Everybody,
                Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                The outputs marked 12v and 20v are all measuring only 1v.
                The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                The capacitors physically look clean (no bludgesor leaks) and...
                07-03-2025, 01:12 PM
