i have a samsung 55in tv its a ln55c630K1FXZA it still works just gets lines in picture. im looking for s new main board or one that will work with my model tv. any help would be greatly appericated. bn94-02701e is the board tag.
samusng 55in tv lines on
https://www.facebook.com/Telford-Tel...7894576335359/Comment
Re: samusng 55in tv lines on
i know the pannel has a problem if i tap the ribbon cable that goes to bn94-02701e it fixes it for a little while. it also has 2 hdmi ports that came disconnected. i cant find these boards anywhere. are there other boards that are compatible? thanks for the help.Comment
Images of the boards please, also have you reseated and cleaned the wires ? Seems like motherboard fault to me not the panel.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Had a 55" Sammy that displayed similar symptom...My lines were green...new Main Bd solved my issue.Comment
Maybe give the Mb a reflow my bet that the issue is bad Bga solder under one of the heatsunk cpu's.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Did you check here? https://www.shopjimmy.com/catalogsea...ln55c630K1FXZA
Then look for the boards on eBay.Comment
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by fredtredHello!
I have been trying to solve this issue the past 12 months to no avail. I have been a lurker here during that time but finally decided to post my problem and see if anybody knows a solution.
Problem
My tv (OLED55CXPUA) has an issue where it displays horizonal lines of dotted artifacts.
(See Attachment 1)
Self Diagnosing
After a very long troubleshooting period I traced the issue to the T-Con board. If I gently flexed/bend the board I could make the display go from GOOD to BAD and vice versa. I have ruled out the connectors/wires... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... - Loading...
