Samsung un39fh5000f Power issue?
  • birdboy385
    • Nov 2015
    • 145
    Hello beautiful electronics people. I have on me a 39" Samsung LED tv. The tv appears to not turn on properly and I shall explain to the best of my knowledge what is happening.
    Upon plugging in the tv, I hear the Samsung start up tune. It's that tune most of the newer samsung tvs have.
    Then the standby light blinks 6 times.
    The tv shows no picture after that nor any time during this "boot" process. I've held a light up to the screen during this "boot" to see if it could just be bad backlights but do not see anything onscreen.
    I will also note that after the boot process finishes if i use the singular button underneath the standby light will flash, almost seeming to be recognizing input.
    I've tried holding the button in to see if i could reboot the tv but the light just constantly blinks.
    I've read online where someone had the same tv where they had it blinking 6 times and it was related to a firmware problem after someone messed with the service menu.
    I've opened the tv and found no obvious signs of damage to the boards.
    If this is related to the firmware, does anyone know of a way to possibly factory reset the tv to clear the settings?
    If it's not that, what are the next steps I should take?
    Thanks everyone for reading and to everyone who helps contribute
    Re: Samsung un39fh5000f Power issue?
    I would at least check the DCV at the D+ of the LED connector.
    I had to replace two strips not too long ago, there are 3 strips connected in series.
    http://www.shopjimmy.com/catalogsear...ng+un39fh5000f
    • birdboy385
      • Nov 2015
      • 145
      ew fun lol. I hate disassembling panels. What is the D+ ?
        D+ (there are two of them, you can check either one of them) is the label on the LED connector CNL802.
        You will have black probe on the chassis, red probe on the D+ then turn on the TV and see if the Voltage rise up higher then 210VDC and then come back down after 3~4 seconds, record those readings.
        Samsung BN44-00496B?
        or
        Samsung BN44-00666A?
        • birdboy385
          • Nov 2015
          • 145
          Oh wow I'm a dingus lol. I was looking a tthe wrong connector on the image you sent me. I see where it is now. I will test it and report back. Thanks.
          • birdboy385
            • Nov 2015
            • 145
            Samsung BN44-00666A is the model of the power board. In terms of the reading, I seemd to be getting a rather continous reading of around 205-210V. I can try retesting it but that was about what i'd get.
              You have open circuit in the LED string. If you look at the Voltage chart on the board, you will see 135 VDC for the LED supply Voltage when it is loaded with working LED string.
              Pictures provided by shopjimmy.
              • birdboy385
                • Nov 2015
                • 145
                My apologies, I'm afraid I just realized I made a mistake. I took the reading while the connector for the LED's was not connected. I will reconnect the cable and redo the test.
                • birdboy385
                  • Nov 2015
                  • 145
                  Ok I redid the reading with the connector on. I am still getting g over 200v continuous. So I agree that I have a bad LED string. Obviously the next step is to disassemble the panel. Once I get that far. How would I go about diagnosing the led strip or individual leds. Or would it be advisable to replace all 3
                  • birdboy385
                    • Nov 2015
                    • 145
                    Sorry, really not sure how to proceed now
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      this video shows you how to strip down the tv too get too the leds
                      https://www.youtube.com/watch?v=YgaL6X6eSaU
                      and reece has some good videos on how too test the leds and also replace them using diffrent methods
                      https://www.youtube.com/channel/UCKI...-hKW14NI-q-6Mg
                      But please be carefull as the lcd screen is so thin etc there so easy to crack/damage
                      • birdboy385
                        • Nov 2015
                        • 145
                        Thank you very much. The fun part of the project begins lol.
