Samsung un39fh5000f Power issue?
  • birdboy385
    • Nov 2015
    • 145
    Hello beautiful electronics people. I have on me a 39" Samsung LED tv. The tv appears to not turn on properly and I shall explain to the best of my knowledge what is happening.
    Upon plugging in the tv, I hear the Samsung start up tune. It's that tune most of the newer samsung tvs have.
    Then the standby light blinks 6 times.
    The tv shows no picture after that nor any time during this "boot" process. I've held a light up to the screen during this "boot" to see if it could just be bad backlights but do not see anything onscreen.
    I will also note that after the boot process finishes if i use the singular button underneath the standby light will flash, almost seeming to be recognizing input.
    I've tried holding the button in to see if i could reboot the tv but the light just constantly blinks.
    I've read online where someone had the same tv where they had it blinking 6 times and it was related to a firmware problem after someone messed with the service menu.
    I've opened the tv and found no obvious signs of damage to the boards.
    If this is related to the firmware, does anyone know of a way to possibly factory reset the tv to clear the settings?
    If it's not that, what are the next steps I should take?
    Thanks everyone for reading and to everyone who helps contribute
    Re: Samsung un39fh5000f Power issue?
    I would at least check the DCV at the D+ of the LED connector.
    I had to replace two strips not too long ago, there are 3 strips connected in series.
    http://www.shopjimmy.com/catalogsear...ng+un39fh5000f
    • birdboy385
      • Nov 2015
      • 145
      ew fun lol. I hate disassembling panels. What is the D+ ?
        D+ (there are two of them, you can check either one of them) is the label on the LED connector CNL802.
        You will have black probe on the chassis, red probe on the D+ then turn on the TV and see if the Voltage rise up higher then 210VDC and then come back down after 3~4 seconds, record those readings.
        Samsung BN44-00496B?
        or
        Samsung BN44-00666A?
        • birdboy385
          • Nov 2015
          • 145
          Oh wow I'm a dingus lol. I was looking a tthe wrong connector on the image you sent me. I see where it is now. I will test it and report back. Thanks.
          • birdboy385
            • Nov 2015
            • 145
            Samsung BN44-00666A is the model of the power board. In terms of the reading, I seemd to be getting a rather continous reading of around 205-210V. I can try retesting it but that was about what i'd get.
              You have open circuit in the LED string. If you look at the Voltage chart on the board, you will see 135 VDC for the LED supply Voltage when it is loaded with working LED string.
              Pictures provided by shopjimmy.
              • birdboy385
                • Nov 2015
                • 145
                My apologies, I'm afraid I just realized I made a mistake. I took the reading while the connector for the LED's was not connected. I will reconnect the cable and redo the test.
                • birdboy385
                  • Nov 2015
                  • 145
                  Ok I redid the reading with the connector on. I am still getting g over 200v continuous. So I agree that I have a bad LED string. Obviously the next step is to disassemble the panel. Once I get that far. How would I go about diagnosing the led strip or individual leds. Or would it be advisable to replace all 3
                  • birdboy385
                    • Nov 2015
                    • 145
                    Sorry, really not sure how to proceed now
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      this video shows you how to strip down the tv too get too the leds
                      https://www.youtube.com/watch?v=YgaL6X6eSaU
                      and reece has some good videos on how too test the leds and also replace them using diffrent methods
                      https://www.youtube.com/channel/UCKI...-hKW14NI-q-6Mg
                      But please be carefull as the lcd screen is so thin etc there so easy to crack/damage
                      • birdboy385
                        • Nov 2015
                        • 145
                        Thank you very much. The fun part of the project begins lol.
                        • Kjell
                          Samsung Series 9 - BIOS issue
                          by Kjell
                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                          08-01-2025, 09:15 AM
                          09-07-2024, 05:50 AM
                        • Nairolf
                          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                          by Nairolf
                          I have a Samsung DM32D display.
                          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                          Here’s what I have tried so far:
                          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                          From these tests, I suspect the problem might be on the mainboard. Could anyone...
                          08-24-2025, 03:47 AM
                        • vincentedel
                          Samsung SyncMaster 740n Phase Control Issue
                          by vincentedel
                          I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                          I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                          04-22-2025, 12:33 AM
                        • FourRunner
                          Display issue Samsung TV UA65JS9000W
                          by FourRunner
                          I purchased a used Samsung TV model UA65JS9000W recently knowing it had an issue with the screen. When switched on the picture was bright both sides of the screen but a little darker in the middle of the screen. Thinking this was the back lights (side mounted LCD strips) I replaced these, however the issue is still there. I am now thinking it may be a TCOM issue, but am not sure, any advice on this would be appreciated. Also whilst changing out the back lights I noticed the the thick clear plastic sheet (maybe 1.5 to 2mm thick) below the diffusers there is cracking (up to 75mm) on the sides and...
                          10-03-2024, 07:05 PM
