Samsung UN55C9000 dead
  • Andyy
    • Aug 2016
    • 28
    Re: Samsung UN55C9000 dead
    Originally posted by ajshoe
    NO schematic available = total guessing in the dark on this set.
    You don't need a schematic. Instead of guessing, you can go through step by step systematically. Start with the the suggestions outlined in the previous posts above....
      What is the display screen that you hook up and caused the main fuse to blow?
      The LED backlights on the screen draw very small current, the T-CON may be drawing 5A at 12VDC.
      To cause the 6.3A main fuse to blow something has to be badly shorted out.
      How about the main board, was it connected but the so call display screen is not connected, is that right? Something is not clear or making sense to me.
      • CapLeaker
        Leaking Member
        • 8325
        Can't help much. I already asked what we needed to know. Without it the answers, I guess you hafta throw parts at the TV.
        • ajshoe
          ajshoe
          • Dec 2012
          • 477
          • usa
          Ok - spent some time on this set - Main board has a VDR with spot and crack in it. pretty sure this has something to do with main fuse blowing with docking board attached. does anybody know what this VDR is and where available ??
          Have to admit - this is the most idiotic tv design I've ever come across.
            That is the NTC for inrush current limiting, it will be damaged if load is shorted because it is connected in series with the load, and that is the reason blown fuse too, you have shorted circuit in your unit some where.
            Rating is 10 Ohms at 25C, the size is 15mm Dia.
            • ajshoe
              ajshoe
              • Dec 2012
              • 477
              • usa
              #26
              will a NTC 10d-15 work as a sub ?? The short is some diodes that bad. replaced diodes but noticed this VDR is not good. thanks
                That will work: DSC
                http://www.dscelec.co.kr/k-products-2-5.htm
                https://www.amazon.com/NTC-10D-15-Cu.../dp/B009JJCETI
                • ajshoe
                  ajshoe
                  • Dec 2012
                  • 477
                  • usa
                  #28
                  new diodes, new VFR - same result. going to force "Power on" and check voltages.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    #29
                    Same set here found main transistors QM803 and QM804 (both 18N50C) one shorted-changing both.Took mains fuse out which is a 6.3amp 250v ceramic type, ntc is reading fine. Also changing ICM80 which is the controller for both transistors the PN of that is ICE1HS01G Ic though this tests fine still swapping it. Also no shorts on the output or any other device so it should fix it. Will update and make a thread.
                    • ajshoe
                      ajshoe
                      • Dec 2012
                      • 477
                      • usa
                      #30
                      any luck on fixing this un55c9000 ?
                        09-07-2024, 05:50 AM
                        09-06-2024, 11:40 PM
                        09-06-2024, 08:40 PM
                        Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                        This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 06:20 PM
