Samsung UN55C9000 dead
  • ajshoe
    ajshoe
    • Dec 2012
    • 477
    • usa
    Have a samsung led lcd flat screen (And I mean flat - only 1/4" thick screen !).
    This is model #UN55C9000ZFXZA. unit is completely dead - electronics are in base. any body have any experience with these ?? I can't find schematic or any info on these tvs. thanks
  • f67bird
    Technician
    • Apr 2007
    • 57
    Re: Samsung UN55C9000 dead
    Go to http://www.toms-service-manuals.com
    Go there and choose Samsung for the brand. You should find a fast track for this model to help you troubleshoot it.
    Learner
    • CapLeaker
      Leaking Member
      • 8196
      measure all the pins on CNM801. Post back the pin name with the voltages measured.
      Verify that you have STBY (5V) voltage. If you do, but get nothing back on the PSon and BLUon pins, you may have a main board problem.
      Get the Service manual from posted above and look at the "power on sequence" and "to force the backlight on".
      • ajshoe
        ajshoe
        • Dec 2012
        • 477
        • usa
        thanks guys - downloaded fast track. probable cant look at it til next week as out of town.
        • ajshoe
          ajshoe
          • Dec 2012
          • 477
          • usa
          took base unit apart - blown main fuse. replaced it, blows when 110V applied. disconnected base from display screen - base unit turns on with new fuse. connect display screen, main fuse blows. bad display screen ??
          t-con board is located on back on display screen along with IR board & 3D board
          will take apart display screen to get shot of TCON bd
          • CapLeaker
            Leaking Member
            • 8196
            Post some high resolution, straight shot pictures of YOUR boards. So we have something to see.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Originally posted by capleaker
              post some high resolution, straight shot pictures of your boards. So we have something to see.
              +1
              • ajshoe
                ajshoe
                • Dec 2012
                • 477
                • usa
                pics of base boards (1-3) pic 1 is power supply, pic 3 is main BD
                pics of display screen boards (4-5)
                pic 4 is T CON BD - 5 is docking BD
                • CapLeaker
                  Leaking Member
                  • 8196
                  Can you explain that any better what happened?
                  "took base unit apart - blown main fuse. replaced it, blows when 110V applied."
                  This sounds like something is wrong in the primary circuit of the power supply.
                  "disconnected base from display screen - base unit turns on with new fuse."
                  Contradicts the first sentence, because I thought the fuse in the primary just blows as soon as you plug it in.
                  We really need to clearly eliminate one thing after the other. That's why I asked specific questions on my post #3.
                  For now, I just want you to disconnect the main board from the PSU, leave the backlights connected, jump PSon to STBY and plug the set in.
                  The power supply should turn on and the backlights should light up. If all this is good, measure each pin (look post #3) on that connector and post it with the corresponding pin out name.
                  • ajshoe
                    ajshoe
                    • Dec 2012
                    • 477
                    • usa
                    got tv DEAD. I took apart base (has most of the electronics are in it) and found blown main FUSE. replaced it and fuse blew again.
                    disconnected base from display screen, replaced main fuse and then base unit powered up. has stdby 5V. If I connect base back to display screen - main fuse blows. I will take some voltage measurements of base unit tonght. guessing TCON board must be loading down power supply. can't find service manual for this set either
                    • CapLeaker
                      Leaking Member
                      • 8196
                      Read my posts again on what exact tests I wanted you to do. This will give us answers, and we can proceed further. The rest is just stabbing randomly around, like just throwing parts at it until it works.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Fair play Samsung cramming that in there, please tell me its fan cooled ? Also the Tcon wont be blowing the mains fuse. Listen to what CL says.
                        • ajshoe
                          ajshoe
                          • Dec 2012
                          • 477
                          • usa
                          Haven't followed your directions on posts yet. I disconnected all connections to docking board - plugged docking board in and powered up - main fuse blows. Before this the main base unit was powering up and working without display screen (which includes docking board) plugged in. I assuming the docking board is bad. anybody have any experience with these ?? Are they repairable ?? or just replace - saw a couple on EBAY. thanks
                          • ajshoe
                            ajshoe
                            • Dec 2012
                            • 477
                            • usa
                            ordered new docking board. there is no fan in this unit (no room !)
                            • CapLeaker
                              Leaking Member
                              • 8196
                              did you at least verify if there is actually something shorted on that docking board?
                              • jhuncruz2007
                                • May 2012
                                • 14
                                • Philippines
                                nice idea.
                                Last edited by jhuncruz2007; 08-26-2016, 08:19 AM. Reason: sorry typographical error
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Keep us updated.
                                  • ajshoe
                                    ajshoe
                                    • Dec 2012
                                    • 477
                                    • usa
                                    bought new docking board - same result. nothing attached to docking board and the main fuse blows. NO schematic available = total guessing in the dark on this set. Would the docking board draw excessive current if the LEDS and TCON BD are not attached ??
                                    • culcuhain
                                      • May 2016
                                      • 186
                                      • U$@
                                      Check out Post #3.....
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        +1, CapLeaker has offered you some good advice.
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
