PE0702A, V28A000962A1 (5V Yes, 12V/24V NO)
  • Badger237
    • May 2020
    • 14
    • United States of America
    Re: PE0702A, V28A000962A1 (5V Yes, 12V/24V NO)
    Good call on the FET's! Q821 was showing shorts between all pins, I removed it from the circuit to confirm that and that the pads were not shorted to each other. I should also point out that there are marks around the two power resistors near the FET's where it looks like it got a little hot. Will be ordering a new FET today.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Check the gate resistor when replacing the FET. I would also change Q820 to be on the safe side and again check the gate resistor
      • Badger237
        • May 2020
        • 14
        If by the gate resistors you mean R827 and R828, they check out, those are the resistors I had mentioned had burn marks around them. Their resistance is still spot on, so I'll let them stay. While checking those, I discovered one of the fusible resistors had opened, R821. Will replace Q821 and R821. R820 is still closed and Q820 still checks out, so I plan on letting them go as well, if I was fixing it for someone else maybe I would change them.
        • Badger237
          • May 2020
          • 14
          I can't seem to find a replacement for R821, it is a 3W 27mOhm cement resistor from Noble, every one i find is either the wrong wattage or the wrong resistance. Maybe I'll just solder a wire there instead...
          • Badger237
            • May 2020
            • 14
            Parts are ordered will update in five days...
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #26
              Are you certain R821 is 27mOhms?
              If Q820 & Q821 are in the same circuit then when one goes it can put a strain on the second one and weaken it.
              • Badger237
                • May 2020
                • 14
                #27
                So here is the update:
                Parts installed, when powered they are still good
                However, these parts made no difference at the output. I still have 5v1, but everything still reads zero referenced to board ground. The 5 volt relay still isn't closing, I have tested it out of the circuit and it works fine, that's whats holding up the 120vAC to the second bridge rectifier. When I short the contacts, the rectifier kicks back up to 160vdc. Even this doesn't allow 12, 18, or 24vdc to be seen at the output. The relay still has 5v at the coil, but there is an open circuit somewhere that isn't allowing the current to flow to fire the relay.
                Is there a way to bench test this board properly? What pins do I have to send voltage to in order to get it to switch? I have been shorting 5v1 to POW-TV. Whats even more confusing is that there appears to be a path to ground from the relay coil through possibly a diode and a capacitor. Is it possible that one of the IC's is controlling the coil?
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  #28
                  Have you found a schematic for the power supply. You have four red wickman fuses, the red circular fuses. Are they all OK.
                  There's a resistor alongside one of the relays with a dark mark on it but the picture is not well focused. It could be R853. Have you checked it out?
                  There are also 4 white large ceramic fuseable resistors that you can test are not open circuit. Also check R850 which should measure 1.8 ohms.
                  https://www.youtube.com/watch?v=ttrSsgkI5TE
                  • R_J
                    • 9627
                    Does POW_TV connect to JP051 (near the relays)? Also does Q8510 emitter connect to hot ground (JP062)
                    If the above is correct, POW_TV connects to R8510 which turns on the base of Q8511, Q8511 collector connects to 5v so when turned on the emitter supplies 5v to Q8510 base, which when turned on connects the relay coil to hot ground.
                    • Badger237
                      • May 2020
                      • 14
                      #30
                      Here are my findings:
                      I will say I cannot confidently determine the direction of the coil diode or that the transistors are NPN or PNP without removing them from the circuit, and they are SMT and small which is a huge pain for me. I will energize the circuit and take voltage measurements tomorrow.
                      • R_J
                        • 9627
                        The diode is backwards, the cathode should be to the supply (5v) Do the transistors have any markings? you may need to clean them with alcohol or something similar to read them.
                        Q8511 might be (LY)
                        Q8510 might be (CCA)(CCB)
                        • Badger237
                          • May 2020
                          • 14
                          #32
                          Good call on Q8510, I powered the circuit (shorting 5v1 to POW-TV with 1k Ohm resistor) and found sufficient voltage at the base. After removing the transistor from the board, I tested it and found an open in all directions between all pins. Will attempt to find a replacement, as the transistors I have are all THT.
                          • R_J
                            • 9627
                            Q8511 (LY) = 2SC4116
                            Q8510 (CCA) = 2SC3326
                            POS software keeps changing upper case to lower case??
                            Q8511 (ly) = 2sc4116
                            q8510 (cca) = 2sc3326
                            • R_J
                              • 9627
                              I enter this:
                              and it changes to the top two lines??
                              • Badger237
                                • May 2020
                                • 14
                                #35
                                Howdy everyone!
                                Good news, after soldering in the new transistor (I ordered a CCA and they sent a CCB) the relay now closes when the 1k ohm resistor is placed between 5v1 and POW TV. I still get no rail voltages, however. Is there another pin that needs 5 volts? both bridge rectifiers are at full power (160V), and I am testing it on the bench. What do I need to do to get 12, 18, and 24 on the meter?
                                • Badger237
                                  • May 2020
                                  • 14
                                  #36
                                  After reinstalling the board, I get 5 volts on 5v1 and 3.2 (pretty much 3.3) on POW-TV, which closes the relay. I have found 11.6 volts on the rectifier side of T880, and zero volts on the other side. Still no voltage at the output pins.
                                    • 12332
                                    • U.S.
                                    #37
                                    • R_J
                                      • 9627
                                      Check the voltage across the large cap C820, You can use JP027~029 as ground and F820 as positive.
                                      Transformers operate with ac voltage. If you say you are measuring +12 volts, Where exactly, T880 has rectifiers on the primary side and the secondary side.
                                      What voltages do you have on plug PJ90?
                                      Have you checked ALL the small fuses on the board?
                                      • Badger237
                                        • May 2020
                                        • 14
                                        #39
                                        All fuses are good
                                        The side of T880 with 11 volts is the side with the large bridge rectifier (Away from the plugs for the main board)
                                        Only voltages I have at PJ90 are 5 on 5v1 and 3.3 on POW TV. The relays close when everything is hooked up and I plug it in. I have strong reason to believe that the main board is toast due to the lighting strike, so at this point I am only trying to make the power board turn on by itself before I order a new $75 main board
                                        • CoinCoin88
                                          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                          by CoinCoin88
                                          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                          09-15-2025, 03:36 AM
                                        • CuriousJohn
                                          Burco boiler power problem
                                          by CuriousJohn
                                          Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
                                          Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
                                          This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
                                          12-22-2024, 10:25 AM
                                        • valvashon
                                          Repair Success! Middle Atlantic UPS2200R-IP
                                          by valvashon
                                          Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                                          Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                                          02-06-2024, 12:54 PM
                                        • jm1234
                                          9V relay temperature 40C
                                          by jm1234
                                          Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                          I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                          05-09-2024, 03:03 AM
                                        • edugimeno
                                          Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                                          by edugimeno
                                          Hi everyone!
                                          I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                                          I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                                          This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                                          To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                                          I respected the polarity, positive to cathode of protecting diode
                                          So provided all...
                                          04-18-2024, 01:15 PM
